Results 1 to 8 of 8
Thread: Help 1979 honda atc 110 no spark at plug
    Apr 2013
    Nebraska
    3
    I have a 79 Honda atc 110 with a new spark plug. The points are sparking but it will not transfer to the spark plug. How to I test the coil and condenser?? If the coil is bad Where could I find a new one?? I have looked around and there doesn't seem to be any aftermarket for something this old. Will another year and cc size fit?? Thank you all for your input and time. I would really love to get this atc running again.
    6,810
    If you haven't replaced the points replace them even if they look good . 90% of the time its the points .
    Remove the spark plug cap and cut 1/4" off the coil wire and reinstall the cap , this will insure for a good connection .
    After you've done all this and no spark contact me I have coils used and new .
    Apr 2013
    Nebraska
    3
    Thank you very much for the answer. I will try that when I get home in about a week. I will let you know what I come up with. thanks again
    tapage is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Montrose, IA U.S.A.
    166
    You don't have cut the wire off, you can always just use a continuity tester and if it beeps its good.
    6,810
    Showing continuity at the plug cap to wire might not be good enough it has to be a really good connection and by cutting the wire back a little and screwing the cap back on insures this .
    Also by probing a tester into the coil wire to check for continuity can contaminate the wire and cause bigger issues .
    Quote Originally Posted by tapage View Post
    Mar 2012
    Montrose, IA U.S.A.
    166
    o... thats how i found my plug wire was bad by checking continuity...
    6,810
    This is a 79 atc110 coil were talking about the plug wire ISN'T removable from the coil so tell me how your going to check for continuity ...
    I understand your trying to help but your wrong in this case .
    Apr 2013
    Nebraska
    3
    Well I installed new points and set them to .014. The spark is bright at the points. Installed a new plug and set gap to .025. Took a 1/4 inch of the end of the plug wire and I still have no spark at the plug. The coil number is FL501AC. If anyone has a good coil I would be interested in it. my number is 402-416-1497. Thanks
