Results 1 to 15 of 17
Thread: Need help with my 250es big red
    Apr 2013
    southeast, iowa
    13
    I have a 250 big red (1985). When I got it it had all sorts of issues with electrical. So I replaced starter etc and now it turns over and I have good spark. So I then went to next thing and cleaned carb before I try starting it. After I did this I was ready to start it so I tried and it wouldn't. It has good spark and carb gets fuel but seems like no fuel is getting to cylinder/spsrk plug so I dumped a little down cylinder and still nothing besides smoke coming out of carb and smoke filling inside of cylinder and motor. Anyone got any ideas?
    Sarnia, Ontario, Canada
    3,415
    Once your plugs is fuel saturated it's done..a NEW plug would be a good start.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Apr 2013
    southeast, iowa
    13
    I put brand new plug in.
    Apr 2013
    southeast, iowa
    13
    Im wondering why its not getting fuel to cylinder and whats making engine fill with smoke
    Feb 2013
    Adelaide
    127
    Is the carb blocked?
    Jan 2013
    minnesota
    5,911
    Hello
    Are you sure there is gas in the float bowl?
    Just to see if it will fire you might try flammable brake cleaner or startring fluid.Open theb throttle all the way sprsay some in there close the throttle to 1/4 and try it.
    1. Is the gas new, old brown gas won't burn well if at all in your motor.
    2. Do a compression test
    3. Check for intake leaks?
    4. Check valve setting
    5. Check cam timing.
    6. What color was the oild plug?
    7. White/grey smoke is oil black or very dark is gas, what color is it?
    3,415
    If you're saying the 'engine is filling with smoke' you mean the crankcase has combustion gases in it? Then skip to #2 on Barnett's list..
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    3,415
    Quote Originally Posted by 200xManiac View Post
    But then you poured fuel in the cylinder right? And who taught you to do that anyway..it's mental!
    Get another new plug..then do the compression test as stated.
    If this machine is new to you and you've never heard it run you have to start with a basic engine health assessment.
    Until that you're just wasting time..
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Dec 2012
    812
    Quote Originally Posted by dougspcs View Post
    Hey Doug, I've used this tactic many a time working on small engines. I pull the plug, take a syringe and just squirt a small amount of fuel in the cylinder, replace the plug then crank the engine over to see if she fires. Sometimes it helps to narrow things down when troubleshooting. Just wondering what's mental about doing that
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Apr 2013
    southeast, iowa
    13
    Im not 100% sure that there's gas in float bowl. I cleaned carb and it gets fuel to it. Ive never fone compression tests or valves or cams. Spark plug is brand new and smoke I think was greyish
    Apr 2013
    southeast, iowa
    13
    What do you mean?
    Apr 2013
    southeast, iowa
    13
    Thinkn about selling
    3,415
    Crack the flat screw on the bottom of the bowl to see if fuel drains out..
    This will tell you if there is fuel in the bowl.
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    3,415
    Quote Originally Posted by Big G View Post
    I personally don't feel that the use of gas in the intake/spark plug socket, quick start or any other 'backyard' technique provide any diagnostic capacity..
    With a simple engine like these checking spark/valve timing, carb function or lack there of, ignition operation, mechanical function and other troubleshooting are simple and fundamentals that will resolve any issue.
    The practice of dumping unmetered amounts of flammable fluid into the engine is pointless..and potentially dangerous.
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Apr 2012
    USA
    4,133
    Kind of a stab in the dark, but maybe timing? And if the timing is off... you need to check your valves to see if they got bent and the timing chain/tensioner. If timing is spot on, then it is between compression or air/fuel mix getting into the cyl, aka carb.
    Are you kick starting or using the starter? Lately I have seen a few people with problems with electric start, kick start might oddly give different results.
