O.K, so I picked up a 1984 shaft drive Honda ATC the other day really cheap, it was sitting outside for 2 years but everything seemed to be in good shape. Anyway, I cleaned the carb, checked valve clearance, timing chain, timing, plug, fresh gas, etc..& all it does is backfire. I can pull it over & it fires but it wants to rip the cord out of my hands whenever it fires & pops really loud out the carb (I checked to see if the air filter/exhaust was plugged & they weren't). I got it to fire up once for about 3-4 seconds, but it ran really sluggish & died. Did the same thing again 30 pulls later. Now I can't get it to run at all, it just backfires every 5-6 pulls (reason I am not using the electric start is because the splines on the starter gear were stripped. I don't know if this matters, but the sparkplug I took out had a LOT of carbon buildup (the one the machine came with), so I put a new one in. The prevoius owner said he never had it running, but as far as he knows it was working fine 2 years ago. Sorry for typing a novel, any advice you could give me would be appreciatedThanks(I've got 7 hondas & never had a problem like this, even had one that sat in a field for 18 years that runs fine after a good carb cleaning).
