Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: 73 ATC 70 with Tracks
    Apr 2010
    lasvegas nv
    57
    That thing is awesome.....have fun with it.....post a video if possible
    Connecticut
    1,605
    Yes I made the track covers and plates to cover the fender holes. I'll be making pivot stabilizers this weekend (I hope).
    Reviving an old thread. Finally scored a craftsman track blower today and looking for a proven approach or some install tips.
    Cold Lake, Alberta, Canada
    3,014
    Not sure what I can contribute here as someone else did the actual work. I can get you detailed pics if needed. To be honest I've never installed these again since 2013.....wow, where did the time go? You will need to find an axle that will need to be modified slightly if I remember correctly. PM if you would rather go that route.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Connecticut
    1,605
    Please share the pics on here so others can get some ideas too. Curious how you designed the stabilizer bars.
    I was under the impression on some other builds that you could adapt a set of stock hubs and not modify the axle. That is the route I was hoping to take, yet I have extra 70 axles....
    Apr 2020
    Yakima, Washington
    44
    very cool, I missed out on one local hear with tracks a few years ago.
    Dec 2007
    Quebec,Canada
    1,014
    Mine,I built it about 10 years ago and still have it,never had any problem
ID:	266232Click image for larger version.
ID:	266233Click image for larger version.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    3,014
    I managed to dig the kit out and get a few more pics of the setup. There's one extra 1/4" hole drilled which drives the sprocket and a collar that threads onto the original stub that goes into the outer steady bearing. As for the stabilizers I never did get around to making them but gathered all the parts up. My thought was to bolt a plate between the frame and grab handle (both sides) with a threaded stub on it and put a threaded stub on the rear of the track at the idler shaft. Then I was going to make my own shock with equal sized springs inside light metal tubing and use two of those small tie rod things with the threads on one end a rotating ball with hole on the other. I included a concept drawing. The idea being the tracks can travel maybe 4" up or down.
    For the record the complete setup is for sale as we speak. You pay what I paid ($200.00 US) plus you get the fenders and cover plates. Shipping is on your dime also. PM me if interested.
    Attached Thumbnails Attached Thumbnails atc70 tracks 4r.jpg   atc70 tracks 1.jpg   atc70 tracks 7.jpg   atc70 tracks 5r.jpg   atc70 tracks 6.jpg   atc70 tracks 2r.jpg
    Trikes
    1972/73 US 90 Green
    1982 ATC 70
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
