Ok wtf I can't figure out how to mount this little terd on my frame and keep my plastic on, can someone give me some detailed pics of how this works? Do I have to alter the tank to make it work? Thanks.
Trikes:
1973 Honda ATC70-orange!
(2)1985 ATC70
1985 Big Red 250
1985 250R
The tank just kind of sits in the frame where the airbox used to be and the airbox cover holds it in place. You do have to cut a hole in the airbox cover for the fill. Mike from Long Island has an extra cover that is allready cut and I think it's for sale.
Lots O Trikes!!!!!
Yep, got to cut the top of the airbox cover.![]()
1986 Tecate
1984 Tecate
1985 Tri-Z
1986 ATC350X
1985 ATC250R (2)
1985 ATC125M (2)
1982 ATC70 - Original Owner
175 TriMoto Frame with Pro-Tec Rear Suspension
3-Wheelin' since '82
Don't worry Jeb I wouldn't do it except my plastic some ding-a-ling already cracked it, so it's no biggy. All you have to do is just cut 1 hole for the filler and that's it?
Trikes:
(2)1985 ATC70
1985 Big Red 250
1985 250R
The hole is actually a little bigger than the filler. The top of the tank sticks out about 1".
Lots O Trikes!!!!!
how much gas does the zinger tank hold i was thinking about doing this mod also but did no if i wanted to be running out od gas all the time out in a sand pit because i usualy ride right from my house i dont truck my machine to the pits.
looking for a TRI-Z 250 to restore at the moment
LONG LIVE THE 2 STROKES !!!
It holds 1.2 gallons if I rememeber correctly.
"I am going out of this world.....the same way I came in...screaming and covered in blood."
about how long will a zinger tank of gas get me pit riding i want to no if its worth it i just dont want to have to refill it every hour.
Probably not very long. What I'm gonna do with mine is make it so it drains into my main tank when it gets below a little bit, so I have 3 gallons of gas + reserves. heehee
Could I get an above pic of how the Zinger tank mounts?
Trikes:
(2)1985 ATC70
1985 Big Red 250
1985 250R
yeah id also liek to see soem pix of it installed guys i like the fact of being able to take that old tank off the ass end and be able to bolt a high flow clamp on type air filter on the beast in place of the restrictive air intake it has right now.
I don't think you have to take off the main take to put on a clampon filter? DO YOU? IF I DO THAT RUINS ALL MY PLANS NOOOOOOOOOO!
Ahh I think it'll fit, just have to do away with the coolant overflow bottle. make a tube run to the ground.
Trikes:
(2)1985 ATC70
1985 Big Red 250
1985 250R
yeah i herd you do but taking out justthe coolent over flow might work as well but im not sure i herd you had to ditch the rear gas tank all together.
I have a clamp on filter on mine, but it just barely hits the tank, I am going to make an elbow joint to angle the filter a little bit.
PastRides
Originally Posted by atctim
I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!SOON MY PRECIOUS!
can you take a pic of your clamp on filtter it must be a tight fit in there
I dont have any film right now, but I will take some pics asap, you have to ditch, or relocate your overflow bottle.
PastRides
