Thread: Breather box on 84' big red 200es
    Apr 2013
    Pearl River, LA
    22
    Does anyone know how I can make a new box that is more durable and can be sealed good. Maybe like out of PVC pipe or something?
    MN
    3,263
    More durable? How so? The stock airbox doesn't have much for problems if you ask me, and the lid seals quite well on them.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Apr 2013
    Pearl River, LA
    22
    Well the rubber neck that it breathes from doesn't seal good on the end of a PVC pipe. Any suggestions?
    MN
    3,263
    You could make an adapter, but if your trying to make a snorkel for deep water you have a lot of other things to worry about, crankcase breather, rear diff breather, making sure there is no leaks for water to get into the motor elsewhere. Etc..
    I know one guy removed the rubber and replaced it with a threaded pvc adapter like you use for electrical conduit with a big metal nut on it, bolted it into the hole and the siliconed around it. I have never investigated how to do it as i don't intend to be going through deep water.. LOL
