http://www.servicehondapsn.com/fiche...84&fveh=132994
#20 was what I assumed he was posting about.
Wish I could be of help with the VIN situation in trying to sort this out, but I cannot. I know that at least 1 of my 2 '85 R's has an 86/87 engine and the other has an 85 engine, but was not original to the VIN on that trike. So any determination of any possible changeover point regarding post VIN XXXXX would be impossible given my engines I have. Sorry guys....
Trikes:
'85 ATC 350R
'85 ATC 250R
'86 ATC 350X
'85 ATC 350X
'84 ATC 200ES Big Red
'84 ATC 125M
'85 ATC 110
'85 ATC 70/110
I would just call Carlos and ask him then we could all go on with our lives, LOL. I would assume he knows why or how some of the cranks have that recess in the 1985 model. I don't have that recess on my crank and my bike was made on 2/85.
Thats odd but it is what it is. Apparently Honda changed some things up and no longer needed that o-ring.
Find the size and something from something will fit;
If the 84 fits, I have a couple from 2 83/84R's lower ends. I'll be selling off every single bearing and seal etc NEW for those years.
Customer does not call me back, does not answers in PM or Email and hopefully someone at TF13 can get the motors back to him.
It's been 2 years, I have had time here and there but never got a response so time to move it.
No repair manual, no money and no gaskets or rings either. I QUIT!
All the work I did and I get dumped on, just like my tenants do..................
Hello ATC250R and Ride Red 250r
Thanks for all you guys putting effort into this. Honda used to put partial vin's on the motors which matched the bikes vin's back in the "old" days. I don't remember if they did that in 80 on uo though. If you know if they did one could just use the engine vin's. Don't need to know what they are just whether they are before or after the VIN cutoff I posted.
Yeagerb, thanks for the info but Honda went by the vin for cut off dates not the buils date, is it possible you could check to see if yours is before or after the one I posted? If not no problem. I like your Carlos comment he must be one of dem der "engin ears".
Hello
Xxxxx
Ok-I wasnt trying to ruffle feathers. By my comment I just meant that my question wasnt so cryptic that it wasnt comprehendable.-thats all.
Thanks for your comments but if you re-read my original post I guessed EXACTLY what you were doing anyway and suggested not to do that. It would have been less typing for you to simply answer my question with a yes. I’m over it, no problem.
xxxxx
Yes- that thread with BDT is where I also saw it mentioned (1& sometimes 2 orings he says)-guess
not.
Yes this unfortunately a very bad and unfortunate problem when someone who does not know much for help and then some “brainiac” like Carlos, unfortunately gives wrong information, especially when that particular wrong information could possibly even do damage to ones bike. Everyone wants to be an “expert” but unfortunately not all giving info are. I personally don’t want to discourage anyone from at least trying to help another but I just encourage those that do who aren’t absolutely certain about what they are saying that they simply qualify their comments by saying something like “I’m not positive about my suggestion so please confirm with another before you try putting 2 o rings in a place that isn’t designed for even one”, lol.
Xxxxx
after the advice/info here -I will leave it as is. Thanks to all !
Yeah, kinda looks like that's a reasonable decision best based upon the general consensus, just please don't take any more of Carlos's advice,lol.
xxxxx
Carlos from BDT recomended to put two o-rings in. In that thread.
Of course that’s because 2 o rings will last twice as long, don’t you know that?
Xxxxx
I bought an 85 motor from ebay and it also has the o-ring.
Please quit buying o ring water cooled motors, you’re not helping. If it wasn’t for you this thread would have ended a while ago, lol.
xxxxx
all 3 of those parts fiche's are not of the proper parts to determine if there is or isn't an o-ring
Those actually are the correct 3 sections of at least one of the OEM Honda fiches s to show whether it came with an o ring or not. The fiches had dates on the bottom and we would occasionally get updated fiches for the same year. Since ATC300R Seems to keep getting 85 motors with o rings it suggests that either the fiche is inaccurate as I previously mentioned or the ones currently available for online viewing are updated versions of the original 85 fiche which may in fact show an o ring up to a certain VIN.
xxxxx
it seems dirtcrasher got it... looks like an oring to me
Yes, he did as far as the 84 goes and this is the exact same fiche I previously posted a link to but mine was from a different online parts supplier than his.
xxxxx
That’s odd but it is what it is. Apparently Honda changed some things up and no longer needed that o-ring.
Yes, most 2 strokes typically used an o ring in this area. Since this is a high potential leak area it seem highly unlikely that Honda eliminated the o ring intentionally simply to save a mere 20 cents by eliminating it and subsequently run the risk of leaking seals and possibly seized pistons that they would then have to pay for under warranty but one never knows.
xxxxx
Hello
Below is an oem fiche showing no o ring from VIN, ATC250R A (85) ALL-TERRAIN VEHICLE (ATV), JPN, VIN# JH3TB060-FC400019 TO JH3TB060-FC426863
This is the VIN cut off for the crank change on the previous fiche I posted, "2413878". I don’t know why this VIN starts with a “2” and has 1 more digit than the other listed above.
Anyone know what consecutive unit number their 85 bike starts with, 2 or 4 and possibly the build date?
The links I posted are for an 85 watercooled. DC's link was for a 84 aircooled which undoubtedly runs that o-ring.
The original question was for the watercooled engine not the air cooled.
"Maybe" according to atc 300r, some early model watercooled R's had that o-ring. My wifes is on a factory crank and built in 12-84..No oring. I too along with kasey have split several 250R engines. 3 this year for me alone. Probably 10 over the last 5 years. I have never, ever, seen an o-ring in that collar. I know Honda had a ton of vin break-point updates to the watercooled engine. The first ones had 3 small ball bearings for the clutch rod, vs one large one. Different collars for the Kicker shaft, and clutch hubs, etc, etc.
However I have never found and O-ring in the crank collar, parts schematics do not show it, and every bottom end seal kit I have ever purchased, does not list or contain an O-ring for the application on the watercooled crank. Could there have been on a select few? Sure maybe, but for some reason if that is the case, Honda decided very early on in production it was not needed.
Whatever the case, no engine 85 and up I have done had it, kasey has not seen it, and I nor him apparently have any leakdown issues or running problems. So until I see one, I won't care to hunt it down and install it on a watercooled engine.
As far as feather's getting ruffled, I am not.It is a perfectly legit discussion on here, and I am perfectly open to learning new things. If in fact some engines had that O-ring it would be news to me, and I am perfectly willing to accept it, and learn it. But still I hold fast to have never seen an oring there.
Proudly NOT a member of
"Team on the Teat"
So....
Carlos from BDT motorsports called me this morning on some parts I am having built so I decided to ask him about this "mysterious o-ring". He said that NO 3rd gen watercooled 250R's (85-86) came from the factory with this o-ring as shown in the micro fische's that Mosh has posted, thanks mosh! He said that if you pull the bushing off the crankshaft (clutch) side you will see a tiny recess. This is where shops sometimes put an o-ring to seal up the cases during a pressure test if a builder notices that pressure is dropping during a pressure test. Furthermore, he said when performing a pressure test, its a telltale sign that air is seeping past that bushing/seal if the pressure drops .5 lb's in 10 minutes. So long story short that o-ring is a preventative measure for having a completely sealed motor. Lastly, he said the 99.9% of the time you don't need the o-ring because the viscosity of the oil will typically seal around the bushing and seal.
Whew...I feel better![]()
