Results 1 to 7 of 7
Thread: ATC 90/110 Service Manual missing transmission info
    Mar 2013
    Minneapolis
    50
    I downloaded the 90/110 service manual from oscarmeyer and there is not info on the crankshaft or transmission. What's up with that?
    MN
    3,263
    Take a look at the one i have on my manual server, link is below in my signature, see if its the same or not and let me know. I might have some more stuff i could look through for that info that i might not have scanned into the server yet.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Connecticut
    1,605
    Quote Originally Posted by HamptonT View Post
    I downloaded thThat manual also e 90/110 service manual from oscarmeyer and there is not info on the crankshaft or transmission. What's up with that?
    That aftermarket manual also incorrectly lists the correct spark plug used in the 110 model.
    The one suggested is too long a reach
    Jan 2013
    minnesota
    5,911
    Hello
    What info do you need exactly?
    The manual below from kbonly and is much better than the Oscar Mayer one and loads much quicker! You can also go to cmsnl.com for original parts fiche’s with xlnt photos and NOS parts. Click on Honda then click on the blue ATC then click on your bike displacement then click on model.
    SEE PG 41 SIB TRANS, 61 CLUTCH
    http://www.kb0nly.info/ATC/index.php?dir=ATC90%2F
    Jan 2013
    minnesota
    5,911
    Hello
    Here's an OEM parts fiche for an 83 atc 110. Click on blue url below to view. It shows every nut bolt and screw on the bike.
    http://www.cmsnl.com/honda-atc110-19...167/partslist/
    Jan 2013
    minnesota
    5,911
    What is your bike exactly plus year?
    Mar 2013
    Minneapolis
    50
    1980 atc 110
