What's the difference between the two?
To paraphrase..the 200s is chain drive, the 200es is shaft drive.
Lots of other differences, but that's the primary.
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
Taken from the spec sheet on the "old 3WW":
ATC200S
Frame number JH3TB0539EK300001~ Engine number TB05E-2300001~ Engine type 4 stroke, Air cooled Displacement 192 cc Bore x Stroke 65 x 57.8 mm Compression ratio 7.8 to 1 Compression 142 - 170 psi Transmission speeds 5 speed Clutch Type Automatic Oil Capacity 1.43 Qt Carburetion 22 mm Keihin Starting system Recoil Starter Fuel capacity 2.3 Gal , 0.4 Gal res. Wheelbase 46.5 in. Overall Length 72.4 in. Overall Width 42.5 in. Ground Clearance 4.9 in. Seat height 26.8 in. Front tire 22 x 11 x 8 Rear tires 22 x 11 x 8 Front suspension Hydraulic Telecoping forks Rear suspension none Front brake Drum Rear brake Drum Final drive Chain Dry weight 278 lbs Approx. retail new $1,270.00
ATC200ES Big Red
Frame number JH3TB0554EC300001~ Engine number TB05E-6000001~ Engine type 4 stroke, Air cooled Displacement 192 cc Bore x Stroke 65 x 57.8 mm Compression ratio 7.8 to 1 Compression 142 - 170 psi Transmission speeds 5 speed with dual range & Reverse Clutch Type Automatic Oil Capacity 1.43 Qt Carburetion 22 mm Keihin Starting system Electric with recoil backup Fuel capacity 3gal with .03 reserve Wheelbase 48.4 in. Overall Length 72.8 in. Overall Width 42.1 in. Ground Clearance 5.9 in. Seat height 27 in. Front tire 25 x 12 x 9 Rear tires 25 x 12 x 9 Front suspension Telescopic Forks Rear suspension none Front brake Drum Rear brake Drum Final drive Shaft Dry weight 375 lbs Approx. retail new $1,848.00
