Results 1 to 11 of 11
Thread: Damn rusted in bearings.. how to get out?
    ange's Avatar
    ange is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2003
    utah
    195
    They broke apart upon removal, so now just the outside race is stuck in the hub (one on each side).
    There is an internal ridge in the hub that wont allow me to reach through from the other side to push them out.
    Been soaking them in WD for days, still no luck trying to get under them to pry them out.
    Is my best bet puting a cut off wheel on a dremel (which I dont have) and cutting them out in pieces?
    Watertown, New York 13601
    3,382
    I heated mine up and then they came out.
    1985 YAMAHA TRI-Z 250 sold
    2006 YFZ 450
    Aug 2003
    Reno
    203
    Blind Mans Bluff
    You may need to use a "blind bearing puller".
    Probably easier to just take the hub somewhere that they have that kind of tooling, machine shop, transmission shop etc.
    Earnest Hemingway:
    "Motor Racing, Mountain Climbing and Bull Fighting are the only true sports.
    All the rest are children's games played by adults."
    Lots_Of_Nothing's Avatar
    Upstate NY
    2,665
    take the hub and freeze it in the freezer overnight or for a couple hours, then try to pry it out and beat it, then if that doesnt work, while its still cold heat it up in the oven or with a torch
    May 2002
    Texas
    2,670
    Ange, which hub? If its an 84 front hub and If you want to quit worrying about it, I have an 84 front hub on ebay in good shape that doesn't have the bearings in it. It's ready for new ones. ends tomorrow so not much waiting!
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2448271582&category=43 983
    Also, 84/85 have some internal snap rings in the front hub.
    1986 Tecate
    1984 Tecate
    1985 Tri-Z
    1986 ATC350X
    1985 ATC250R (2)
    1985 ATC125M (2)
    1982 ATC70 - Original Owner
    175 TriMoto Frame with Pro-Tec Rear Suspension
    3-Wheelin' since '82
    jdparsons1's Avatar
    jdparsons1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2002
    Toledo, OH
    360
    Quote Originally Posted by 85ATC250R
    If you heat it in the oven, make sure you preheat at 375 degrees for 15 minutes.
    Newfoundland
    5,280
    I had the same trouble with multiple bearings. My father taught me this trick. Take a steel bolt short enough to stand up in the race, like->(/), and weld it in place. Let it cool and use a suitable and long punch and pound it out from the center of the bolt. If the weld breaks then reweld it and repeat. It will come eventually.
    Minnesota
    784
    You might be able to use a dremmel and cut notches in the race that is left and bend them up. I'm unfamiliar with a T3 hub so there might not be enough room.
    3,382
    Quote Originally Posted by jdparsons1
    Throw some rolls in there to and we can have it for dinner.
    2006 YFZ 450
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,241
    the easiest way to get them out is find your local auto shop,, you need a inside jawed slide puller it will pull them right out without any damage!!!
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Do you have an air compressor? If you do, buy a short barrel impact punch, it will pop those baby's right out.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
