Results 1 to 7 of 7
Thread: wheel nut size / tire fell off !
    Jan 2013
    grate white nord
    65
    anyone know the wheel (axel) nut size for the Honda ATC 110/125..
    the wheels came off.. so to speak..on its last ride..
    Dec 2012
    812
    That's why it's important to make sure the cotter pin's in! At least no one was injured
    Sorry, don't know the nut size off hand.
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by steck View Post
    Hello
    ATC 125 is front 12 mm X 1.75 mm thread, rear is 14 mm X either 1.50 mm or 1.75 mm thread castle nuts available at honda shop or industrial hardware store not at home depot..
    You need to list whether it's a 110 or 125 next time, it can not be both.
    Jan 2013
    grate white nord
    65
    Hello
    hey thx. i always thought the 110 was identical to the 125m for the most part.
    yeah, i did some checking and came up with 14mm castle nut (1.5 fine thread). very hard to find around here..
    i found some M14 nyloc nuts that i thought would work, but a buddy said 'no, you have to use a castle nut with washers, and the cotter pin..
    Jan 2013
    minnesota
    5,911
    Hello
    Yes but not everything so I think it’s best to say exactly what your bike is.
    xxxxx
    You don’t have an industrial hardware supply store I’m guessing.
    xxxxx
    You definitely need a thick hardened flat washer the nyloc will work but needs constant checking. It will not fall off like your other one. Torque axle properly.
    Washer Item #1 and nut #13.
    http://www.cmsnl.com/honda-atc125m-1...7.html#results
    Jan 2013
    minnesota
    5,911
    That link i gave you has those original parts available $2.50 each.
    Jan 2013
    grate white nord
    65
    hey thx ! thats why i come on here !!
