Results 1 to 15 of 15
Thread: Penetrating Oil in Cylinder
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    Ok I know this is a trike forum and I'm fixin to talk about a quad, but this is the same principle and people on this forum are much more knowledgable then any other forum I'm in. I have a 92 timberwolf 250 that I just picked up for free everything on this bike is good my friend got a new bike and gave me this one. When I got it the piston was seized in the cylinder. So I sprayed some JB80 in their and I broke it free within 3 or 4 hours. JB80 is an awesome product that all my Dads Cajun customers in Louisiana swear by. Now the thing is can you start a motor with penetrant in the cylinder? Or am I going to have to spray it with carb clean and let it tip over and let it pour out?
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
    Terryville,CT
    1,616
    why not? it may interupt with the mix of air and fuel but wont hurt anything. just spray some carb cleaner in spark plug hole and drop a drop of oil in there after to make sure it doesn't seize again without any oil on the rings.
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Are saying the penetrant will be fine in their or does it need to come out? Kinda confused on what you said.
    3. 85 200m
    Terryville,CT
    1,616
    Either way is fine. Penetrating oil might foul spark plug but that's About it.
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Scootertrash's Avatar
    In the sticks
    4,638
    I guess the most important question here is: Do you know WHY it was seized?
    Have you drained the crankcase oil to see what, if anything, comes out?
    You could do a compression check first to see if it has the compression needed to fire, or you could just try starting it and if it doesn't start, then check the compression. I've done it both ways.
    I wouldn't worry about starting it with penetrating oil in it, however, I would not spray carb cleaner into the cylinder. The carb cleaner will wash the lubricant from the penetrating oil off of the cylinder walls. Since it was seized up, a little lube on the upper cylinder walls when you first start it could be a benefit, and it's definitely not going to hurt anything. Pull or kick it over a few times to get a coating of lube on the upper cylinder walls then give it some fuel and see if it will fire.
    I have a spray bottle of 40:1 gas/oil mix and I spray some of that thru the carb to try starting machines like this, or even if they've been sitting for an extended amount of time. It gives the engine the fuel it needs to see if it will fire, along with a little upper cylinder lube.
    Make sure you update the thread with what your results are.
    MN
    3,263
    I have had trikes that were seized just from sitting, the whole cylinder was rusty above the piston, the way i got them moving again was soak the cylinder with PB Blaster through the plug hole, drain and fill the oil, even overfilling it just a bit, take one of the caps off on the head and pouring some oil in to lubricate the cam and rockers, then after the PB Blaster does its job and it will turn over i toss in a plug and a couple squirts of fresh gas into the carb and get it to fire and run. If it runs i let it idle a while and see how much oil it burns off. Believe it or not i have had some in this condition continue to run without any oil use or smoking after the rings scrape the rust off the cylinder walls. Not saying they will be the best but i had one that ran two years after doing just this before a top end rebuild was needed when it started smoking.
    Just can't kill a Honda.... LOL
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Dec 2005
    Wisconsin
    1,141
    Penetrating oil works good for penetrating, not lubricating. It wouldn't hurt to get a little engine oil on the cylinder and rings to help them seal up and make some compression. Most likely it couldn't hurt anything worse than they already are if you just tried to fire it up. The penetrating oil will burn out if it starts and you build up some heat. Good luck.
    YTM-200, Wheeling machine!!!
    1985 Honda 200x...
    ...Just a simple mild 200x
    NEPA
    7,049
    Clean your carb and tank and start her. You'll be fine
    Sarnia, Ontario, Canada
    3,415
    Quote Originally Posted by atc007 View Post
    I agree with Bill, don't over think it..
    But when it starts keep the revs down..the penetrating oil not being a great lubricant and the rust lip in the cylinder may just burn out what bit of rings may be left if you rev the crap out of it.
    Then sell it and buy a trike!!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Ok we'll I have cleaned the tank out good and I did some what of cleaning on the carb the best I could without air and carb clean ( I'm not where I can get to my shop at the moment ) but I will clean it thoroughly when I get home. The piston was just seized from sitting a while. I'm going to have to check compression. I'm getting a nice blue spark but it looks almost small I don't know that could be how it's supposed to be. I've got new ngk plug in it. And there was a little water in crankcase but not much everything seems to shift fine and piston moves great now. I just can't get it to fire. I tried spraying a little gas in cylinder but that didn't work either. When I get home ill put a tad bit of oil in the cylinder and give the carb a thorough cleaning like it needs.
    3. 85 200m
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Well guys I cleaned the carb and put a new spark plug in and had a spark but nothing happened. So I went to the trusty service manual and troubleshooted the ignition system and soon found out what I had feared, that my stator coil was putting out a low spark. The ohms are reading like 120 to 240 instead of 428 to 523 like the manual says. And a new stator coil for this bad puppy is like $200+ so I'm beside myself, anybody know anyone with a 92-93 Yamaha timberwolf 250 stator coil i can buy?
    3. 85 200m
    Snohomish, Wa
    1,028
    ebay,get a used one. Or check to see if ricky stator has a coil for it.
    85 ATC 250r -Under Construction
    86 TRX250r
    05 KFX400
    02 400EX
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    Were it me and on a first test run/drive machine, I would source a cheap after market or Chinese knock off and try that first. If it cures the problem, run it until you can locate a good used or new pulse coil for it. No sense in spending $200 on a good coil if the rest of the machine ends up being a parts source project. Just my .02 cents
    Good luck and send a pic or two when you have a chance.
    The Goal... All I Need Is The Time...
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Yea I agree Dave ima try to find one cheap and see if it fixes it.
    3. 85 200m
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Well the cheepest i can find is like $150. While I'm not a cheapo I don't want to spend that much on a coil that might not fix my problem. So here is another thing since the coil is a wet coil (submerged in oil) and I know there was water sitting in the bottom of the motor, if there is any rust on the coil do yall think it would be worth my time to try and sand the contact points on the coil and the magneto? I'm willing to spend the money I just want to know it will fix it before I drop a $200 part into a bike.
    3. 85 200m
