Results 1 to 2 of 2
Thread: Adjusting valves on a 90cc, is this normal?
    Apr 2008
    ROCKFORD
    62
    When adjusting valves on a 90cc, is it normal for the rocker arm to move back and forth? If so, do you adjust the valves when the rocker arm is up or down? thanks
    6,813
    Yes the rockers will move a little side to side . motor needs to be at top dead center to adjust the valves , meaning the piston is all the way to the top of the cylinder and the valves are closed then adjust .
