It is my understanding that, along with others, Honda ATC tanks have a history of rusting through and developing leaks. I have two 1980 ATC's. One has what looks to be a perfect tank and one has some slight surface rust on the inside. How do I keep them that way?
There must be a reason that some tanks corrode faster than others. Other than simply leaving it outside in the weather.
One thought was that some people run their tanks empty before longer storage. Or it just happens to be near empty before putting away. And some people use a gas stabilizer for longer term storage.
My theory is that having gas in the tank is probably better than having an empty tank sitting. What do you think?
Also, it may have something to do with the tank vent. It would be very easy to forget to close the vent. Leaving it open could allow moisture inside the tank.
Any thoughts or comments?
