Results 1 to 8 of 8
Thread: Project: Tumblr (1984 Yamaha TriMoto 200 Rebuild)
    Apr 2013
    Las Vegas, NV
    3
    So, 3 weeks ago I picked up this beast, it was in rough shape cosmetically. Needed the carb rebuilt, rubbers and just some love. Yes, that's faux bear fur as a seat cover.
    Spent the last few weeks tearing down...
ID:	168094Click image for larger version.
ID:	168095Click image for larger version.
ID:	168096Click image for larger version.
    Sanded and Rhino'd the chassis...
    Put a Wiseco 68mm HighCompression Piston, Enameled the Engine and Exhaust
ID:	168103Click image for larger version.
    New Rubbers from Duro
    My buddies at work called this the 50/50 Gears of War inspired paint job...Looks kick ass in my opinion.
    Got that hideous seat upholstered with marine grade leather.
    Installed a rear rack and started putting everything back together this past weekend...
    After 3 weeks, I think I've got a winner. Been tweaking the carb the past couple of days. Jetted the carb with a Sigma 6 carb kit. The blue healight tint is from Lamin-X.com for about $7.
    ...and here's my dilemma. Finally got the thing to start w/ and w/out the choke. My needle is on the 2nd from top position, mixture screw is @ 2 1/4 turns, and fuel stop is just about 2 turns from being all the way in...and I'm still running rich. I've looked, searched, asked, downloaded the service manual, and I'm exhausted. Couple of questions...how does turning the mixture screw affect it (e.i. screwing in allows more air or the opposite), same with the fuel stop. I'm frickin' stuck...
    Wheelie's like a beast!!!
    Jan 2013
    minnesota
    5,911
    Hello
    What jets are currently in it?
    Did you modify the slide or carb body as they recommend?
    xxxxx
    How cold was it when it started without choke?
    Did it start easily without choke ie 2 or 3 tries?
    If it starts easily with no choke and it is 60 degrees or less air tewmp it is slightly rich on start circuit.
    Pilot jet slightly rich or idle mix screw too rich.
    Xxxxx
    Good
    xxxxx
    What do you mean by fuel stop?
    Are you talking about the screw used to set the height of the carb slide?
    Do you know which screw is which?
    The screw closest to the motor is the idle mix screw not the slide screw.
    xxxxx
    Please explain EXACTLY in detail what causes you to say this?
    If it “burbles/stutters” under acceleration from a stop or cruising speed it is rich.
    If it simply hesitates and doesn’t go under acceleration then it is lean
    What color is your plug?
    White is lean, med tan is good, DRY black is rich, moist gooey black is burning oil.
    Xxxxx
    Here’s a Clymer’s manual, takes 5 minutes to load..
    http://www.oscarmayer.net/atc/manual...225-fm200l.pdf
    xxxxx
    xxxxx
    If it runs this good your carb must not be off by much.
    Xxxxx
    Does it smoke?
    Can you do compression test, not necessary just curious?
    Xxxxx
    What are your jet sizes?
    Std settings
    Main 102.5
    Pilot 35
    Starter jet 65
    Needle 4l25-3
    Mix screw 2 1/4 - 2 ½
    Float level 21.5 mm
    XXXXX
    CLYMERS MANUAL CARB PG 177-178
    Sarnia, Ontario, Canada
    3,415
    Great looking build..the best kind in my opinion!! The rideable kind!!
    They don't have to look showroom when they're done, but if the inspiration and thought behind it is sound it'll turn heads..
    Good job..
    Quote Originally Posted by StarFury View Post
    In answer to your question..
    1/ if the mix screw is before the throttle plate/slide then it's an air mix screw.
    2/ if after the throttle (which yours is) it's a fuel mixture screw.
    So if you close the screw in theory it will lean, screw it out will richen..for the 1st type the opposite.
    Check your choke plunger and make sure it's seating all the way when the choke is off..if it's stuck part way open you have uncontrolled amounts of fuel dumping into the intake..you'll never get it to dial it.
    And your 'fuel stop'..do I assume you are talking about the idle speed adjuster??
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Woodsrider's Avatar
    Woodsrider is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    Eastern Passage, NS
    238
    What a transformation! Looks awesome !!
    STL
    3,560
    wow man that looks great! and that fur seat was awesome lmao
    what coating is that on the fenders, did i miss that? I like the rhon'd frame too. Bet that's durable as heck
    May 2011
    Logan, Utah
    20
    looks good brother
    Apr 2013
    Las Vegas, NV
    3
    Fuel stop...idle screw. A friend of mine kept calling it while he was over, must've lingered. Yes, the idle adjustment screw on the side. With his help, got it a little more dialed in. Mostly adjustments to the fuel mixture screw (Thanks Dougpcs), idle adjustment, and choke plunger.
    Main jet and pilot jet were all swapped out with the replacements from Sigma6. I did however follow those install instructions to the "T" and wasn't too complicated. The tuning gave me run for my $$$.
    Clymer's Manual helped alot as well, Thanks Barnett468
    Jason B, What I did with the fenders: 1, sprayed with Krylon Fusion....2, Rustoleum Bedliner Spray (same stuff as Rhino-lining, used it on the chassis as well)
    Apr 2013
    NY
    Really Nice Job! Use it well!
    Dual 85' Yamaha YTM225's
