A while back I had some issues with my 1989 Yamaha Pro-hauler not starting. After some work I found out is had a torn intake. After that it ran fine. I stuck it in the shed and left it alone for a few weeks. When I went out to use it was hard to start again. I sprayed a quick squirt of starting fluid and it started up and ran great. It worked all day with no issues. I would even shut it down for up to an hour and it would start again as soon as I touched the button. I have zero complaints about how it ran that day. The very next day I went out to use it and it would not start for anything. It ran on choke for a few moments but that was it. Since then I have tried a few times to start it with no luck. I do not want to use starting fluid anymore because I should not have to. I think something is out of adjustment in the carb. Any ideas as to what that would be? Maybe the needle needs to be re-positioned, maybe the float it off. If it is the float any ideas how I can find out where it is suppose to be positioned? What about the choke? Is there something with that I should look at?
Here are the specs on my Pro-Hauler:
http://www.yamahamotorsports.com/out...ler_small.aspx
