Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: More starting problems with my Pro-Hauler
    Jan 2005
    Columbus, Georgia-Mid Dixie
    5,301
    Yep, spark is good. I think it is in the carb as well. Maybe the float?
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    83 YTM 200L For sale,
    82 Tri-Zinger 60 For sale,
    8? YTZ 80 Conversion,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    chrs's Avatar
    chrs is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2011
    mi
    153
    Also check your kill switch. If you haven't, check your spark as recommended.
    Jan 2005
    5,301
    The kill switch is clean as well. But if was not working right I woul dnot have spark at all.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    chrs's Avatar
    Aug 2011
    mi
    153
    Sent you a pm
    Jan 2005
    5,301
    Got it, and replied.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Abrams, Wisconsin
    739
    Quote Originally Posted by LonesomeTriZ View Post
    Hard to say till you tear it down. When you rebuilt it, did you take all the jet tubes out and clean out all the little ports?
    86 250sx - old reliable
    another 82 110
    -gone but not forgotten-
    82? 110 - why did i sell it??
    84 225dx - meh, it was a pile
    Jan 2005
    5,301
    Yes. I spent extra time on that area and those parts. I am going to tear deeper into it tomorrow when I get home. There has got to be a reason for this.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    chrs's Avatar
    Aug 2011
    mi
    153
    Sent another
    Jan 2005
    5,301
    Got it.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Aug 2004
    Ab Canada
    4,368
    How good of shape is your battery in..? The old pro hauler on the farm growing up..i seem to remember the battry and/or charging system being the culprit of slow, bad starts alot..thing was always on the charger..this was years ago..happen to have a wire diagram? also a compression reading would be nice...seem to remember them burning out oil pumps n camshafts...among other things...
    1985 Tri-Z-
    Jan 2005
    5,301
    I just got in from working on the Pro-Hauler. When I tore it down the last time I noticed the seal above the slide was bad. So I replaced it. It was a little thicker, but I did nto think it would make that much of a difference. Well, I was wrong. Instead of pulling the carb apart agin I pulled the slid eout first. I moved the pin needle down one notch, put it all back together and it started fine. I shut it off several times and it starte right back up with out choke. In the next few days I am goinf to pull it out to get some work done and we will see then if it is finally repaired. I am still confused on why it started and ran great for one day but not after that.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    Abrams, Wisconsin
    739
    Good luck, it would be great if it's something simple!
    another 82 110
    Jan 2005
    5,301
    For a change...
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
    volfan537240 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Eufaula, AL
    292
    Low compression would make it slow to start and cause idle issues. If it started with starting fluid though, I'd say its a carb problem. Could be bad gas. I've seen ethanol gas go bad in a couple of weeks. I run ethanol free in my toys for this very reason.
    85 tri-z (in pieces)
    421 cub banshee
  15. #30
    Jan 2005
    5,301
    I need to tracvk down a station that sells ethanol free gas.
    85 Tri-Z's
    85 Quad-Z,
    85 YT175 For sale,
    83 YTM 225DX,
    85 YT 125,
    89 Pro Hauler 230,
    05 YFZ 450,
    99 V-Star,
