Originally Posted by
kirkallen143
Good to know, also did the 350x triples come with a pinch bolt for the stem? I know the 83-84 250r and 200x did. I have been researching stem diameters and the xr200 that I have is 24mm at bottom and 22.5mm at top, whereas the atc's are 26mm. I think if I can get triples with a pinch bolt for the lower stem, I could use some shim stock to make up the 2mm difference.
Even if I did use the 250r or 200x triples couldn't I run the front axle trailing instead of leading to make up for the rake issue?
How about the other triples like tri-z or tecate, wonder if they are compatable?
More research...
Kirk
