Results 1 to 11 of 11
Thread: need help finding parts!
    Apr 2013
    paducah ky
    3
    I need some help finding a ring gear and axle for my 85 Honda 250Sx, I've looked on Ebay and several other places and can't find the ring great itself anywhere. Would greatly appreciate any help..
    Jan 2011
    Choctaw, OK
    2,755
    I have 6 trashed diffs in the attic. Tomorrow I'll get up and see if there's a good ring gear but you might be better off buying a whole diff that needs rebuilt. I have the tools to rebuild them and wont kill you on price. I have a bearing and seal kit sitting here already. I believe I also have an 85 axle in the attic.
    Apr 2013
    paducah ky
    3
    Sound great, I've stripped the splines between my axle and ring gear and have new seals and bearings in this differential already, kinda why on trying to just get a new ring gear
    Apr 2013
    paducah ky
    3
    And an axle would also definitely be interested in
    Larry T Moore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2013
    Indiana
    358
    theres a guy in bardstown with BIG RED for sale on craigslist for 500 bux...has a street bike front end on it
    Howdy's Avatar
    Celina, Ohio
    10,079
    I will be at the shop tomorrow and will do some checking. I know I have a 85 250es axle and differential in great shape, but I know the differential is geared different and the axle has a different part number.
    Howdy
    Dec 2007
    Quebec,Canada
    1,014
    Why change the gear? The problem is only the spline in the gear? Keep your gear,just change the splined bushing,it's just pressed in the gear. trx300,trx250 250sx and 250es use all the same.
    1986 ATC500X
    1985 ATC250SX
    1985 ATC200X
    1985 ATC250R
    1986 ATC250R
    1984 ATC250R
    1981 ATC70
    1984 ATC70
    1985 ATC70
    Custom built ATC70 / 250R laydwon swap
    1986 ATC250SX FATCAT
    Jan 2011
    Choctaw, OK
    2,755
    Gotcha. I'll scope it out tomorrow. Just know that the ring and pinion gears are match machined so mismatching ring and pinion gears can cause a mild to severe growl.
    Jan 2011
    Choctaw, OK
    2,755
    Quote Originally Posted by Howdy View Post
    Howdy
    ya the ES and SX axles are different.
    Jan 2011
    Choctaw, OK
    2,755
    I have an axle but the SX ring gear is questionable. The left side sealing surface is pretty corroded.
    Apr 2012
    USA
    4,129
    What kind of price range are you looking at? I have basically a complete 250sx in rideable shape but has no plastics and the entire front end is a 250es with a bad gas tank. Might be willing to part it out if I can get a fairly large item sold off it such as the rear end or engine.
