Hello tvpierce
Ok, I just looked at an advancer in the link below. It looks like the weights stop on the upright tabs. You can compare yours to this to see if it appears worn [the one in the photo does not] irregardless here’s an easy way to limit it’s amount of total advance. I have done the following before on many advances.
Get a piece of thin wall, non reinforced rubber tubing from either the hardware store or auto
parts store that is around 1/4” id [gas line is WAY too thick] and 6” long. Cut two pieces that are the same size length as distance from the base of the weight stop to just under the top where it has the little nub on each end [the trapped height] then put a small amount of grease on them and install them. Put a little grease on the back side if the spring touches it but it should just barely graze it if at all if the tubing thickness is correct.
Do your stops look worn on the sides, any photos?
