Hi have a 85 tri-z with some mod... here the list
-Wrench report phase 2 done.. About 0.86mm(0.033'') (piston to head clearance)
-full dg
-38 mm keihin airstriker
-stroked crank
-v force 3 out a kx 125 but i change petal for softer
-brand new piston ring
-top and bot fresh rebuid tested for air leak
-brand new stator
spark plug br8es nice brown colour.
-About 186 psi compression ( Running with a little octane to make it run tight)
I just finished the bike and had issue about jobbber head gasket leaking into cylinder So i just installed a yamaha head gasket and the gasket didnt blow up right aways. But i notice i sound who seem to come from water pump.. but when i run the bike he leak prestone off the cap when i ride it a bit. (just some small drop) Have no prestone bottle. and no termostat. I have clear hose for prestone + i tested witout prestone cap and when i spin the bike i can see small bubble like the water pump seem to run normally.
Problem is I maybe run the bike for 5 min and cant handle my hand on the water pump cover... really hot .. the rear exhaust same thing ... really hot cant even touch it. So tested out my yz 250 09 about same riding time and touch my water pump cover and still not hot and rear pipe is cold...
Without that bike seem to be great and hes really fast. Slow idleling #1
Help me ! haha
