Quick question on cylinder jugs
I am building up a 200S engine I have. I'm getting to the top end and I need some help. I have 3 Cylinders.
Cylinder # 1 is Mic'd at - 65.5828
Cylinder # 2 is Mic'd at - 65.532
Cylinder # 3 is Mic'd at - 65.5574
I have a Wiseco piston I found that I got new rings for that is 65.50.. 10:25:1.. SN 4394M06550..
Now with that being said would these even be good to use anymore or no? Another question is that if they all are usable, the best would be to go with Cylinder # 2, correct? Well I would think so also, BUT I ran into a problem with Cylinder # 2... It's off of 83-85 200X and the dowel pins are WAY different than I have ever seen. Maybe not way different, but they are pushed in a lot further than I have ever seen. Is this normal? Did they make a certain year model engine like that? Is it usable?
All help appreciated! Thank you!
My Trikes:
1981 Honda ATC250R
1982 Honda ATC 200
1984 Honda ATC 200S
1984 Honda ATC Auto 200X
1985 Honda ATC 200X (Basket case)
