Results 1 to 15 of 25
Thread: 85 tri-z issue with gas leaver
    BiGDawG's Avatar
    BiGDawG is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Millington, Michigan, United States
    384
    where you turn the gas on and off, for some reason while riding it keep moving its self to almost off i'll be riding and it will fall flat and try to stall reach down turn it back on good to go for a few more mins.. sucks having to keep reaching down to turn it back on lol, also not sure if its normal but full throttle down the road it vibrates so bad i can hardly hold the handle bar.
    Mexico
    9,018
    Broken piston skirt maybe?
    crank bearings, rod bearings? ect..... remove the 2nd petcock ... you dont need it
    oile's Avatar
    oile is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2012
    kansas
    600
    Check and see if you have a bent axle or rim.
    N.E. Ohio
    2,002
    West Virginia Chrome it into place...works upto 100mph and comes in a roll for $2.00
    BiGDawG's Avatar
    384
    i only have 1 petcock and it don't hop but i'll still check the axle, the rim's look like junk.. so that could be dose anyone have a good engine shot from the side the kick start it on? some one asked me if it had a bike engine in it
    North Dakota
    1,643
    Quote Originally Posted by BiGDawG View Post
    Should be easy to tell if you have a bike motor in it unless they modded the kick starter some how. The bikes kicked towards the rear and the z kicks toward the front. Ill get you a picture in the A.M if no one else puts one up by then.
    BiGDawG's Avatar
    384
    yea it kicks forward, and they got rid of the stock switch and overheat light just has a toggle down by the seat and headlights ant wired up
    North Dakota
    1,643
    Sounds rigged up lol! Ill get you a pick once I'm done with work tonight!
    Mexico
    9,018
    Does it have a power valve?
    BiGDawG's Avatar
    384
    i feel dumb for asking but this is my first 2 stroke.. whats a power valve look like?
    if i end up needing rim's what my best bet, the tires are like new so
    Mexico
    9,018
    Post a photo of the right hand side of your engine and cylinder and we'll let you know. Your engine came with provisions for a PV but they only came stock on the YZ bikes.
    Aug 2004
    Ab Canada
    4,368
    Its your foot hitting the fuel switch, if your wear high boots or have a tendency to pull the right leg up..it happens..could be wore out o ring and seals too causin it to be a bit too loose..iv shut myself down a few times with this issue i moved the pump to the backside of the mount.
    1985 Tri-Z-
    BiGDawG's Avatar
    384
    i'll grab a pic later today, and i don't think so i just wear normal shoes lol but maybe my pants flapping in the wind could be hitting it, but it dose turn really easy
    Rittman, Ohio
    6,276
    Does it have the same vibration at full throttle when you are sitting still and not going down the road?
