Results 1 to 3 of 3
Thread: 84 200x jet question
    Mar 2013
    paradise ca
    15
    I am just finishing up my engine new timing chain 20 over wiseco 12:1 piston. whats a food place to start with jetting I know its stock with a 110 I will be running av gas 100LL
    thanks
    justin
    Jan 2013
    minnesota
    5,911
    Hello
    It depends what you had before. If it ran fine with a 110 before and the piston is your ONLY change then maybe a 120 and up on the needle 1 position. If it pings you need 110, 112 or 114 race fuel and/or reduce ign timing slightly.
    Mar 2013
    paradise ca
    15
    well fired the engine up for the first time sounds great but can tell its running lean going to grad a few jets tomorrow needle is one 1 and 110 jet so time for a 120, it looses it on the top end seems to just run out of fuel other then that its doing great.
