Thread: new project time
    Dec 2012
    Newfoundland
    140
    new project time
    just picked out a 87 ( appearently) dr 225 yamaha. ...got it for 220$, and shes not pretty, buddy assured me she ran run and had just jumped timing... so i bought it and ended up gettin a spare set of tires and rims ( mudlights 60%) to go along. i thought well i can always try and get the motor in the 200e lol. so i got her on timing....off a good bit and after much f***ing around i have her going and idleing....turns out it has a dg muffler as well but the headpipe is toast....so i take it for a spin and get to second and am impressed. then i hear a wierd sound from the rearend....pull apart and the shaft inside the swing arm has tons of play and the bearing is shot. so im after a complete tear down tomorrow of the rearend and see if its salvageable....will the rearend from the 200e fit?...anyway only have a couple pics so far.
ID:	168588Click image for larger version.
ID:	168589Click image for larger version.
    1985 Yamaha 200E -ForSale!
    1986 Yamaha 250Dr (beartracker swap)Forsale!
    2009 Sportsman 850Xp
    2014 Renegade 800r
    2011 Dodge Ram
    Dec 2006
    St. John's Newfoundland
    1,587
    Nice price. Was watching this one. She has been around but worth a saving indeed
    1986 ATC 250r
    1985 ATC 250r
    1985 X2 ATC 70's
    1985 XL 80
    Dec 2012
    Newfoundland
    140
    rearend is rough, gears are ok at best but every bearing feel out, nothing left
    2014 Renegade 800r
    2011 Dodge Ram
    Dec 2012
    Newfoundland
    140
    man i am pissed so bad, swapped the axle and rearend out of the 200 and spent the day doing a few other things....finally get to go for a ride and the damn timing chain busts..., pull the cover off and sure enough a link ripped right apart, and also notice the cam bearing is shot...i knew the chain was on its last legs, the adjuster is in pretty far but i didnt think it was that close.i dont know if i should just rebuild the 200e again and use that and rebuild the 225 over the summer in my spare time or see if the cam and timing chain are interchangeable and pull them, but then i have the 200 apart and no rideable bike....any info on interchangeability would be greatly appreciated.
    2014 Renegade 800r
    2011 Dodge Ram
    Dec 2012
    Newfoundland
    140
    rearend bearing kit and new timing chain in the mail
    2014 Renegade 800r
    2011 Dodge Ram
