Results 1 to 11 of 11
Thread: "Trikenstine"
    Apr 2013
    Covington, La.
    12
    "Trikenstine"
    I have a 1985 honda 250es big red. I'm trying to get the most power out of it as possible. Would the top end off a 300 fourtrax bolt up? I kno the design is almost exact, but is there any diffrence?
    Worcester, MA
    1,117
    The difference is the stroke of the crank. The bore is the same on both, in fact, the head and cylinder is the same. Supposedly the 1988 trx 300 cam is better slightly, but I doubt it's by much.
    It depends on how intense you're wanting to go, and how much you'll spend. There are ways to improve it, but from what I gather, the you can put a lot into the SX/ES and not get much in return. I believe Dirtcrasher did that with his.
    You can put a full 2wd TRX300 engine in, but you'll have to swap the output shaft which requires pulling the side cover and clutch.
    Apr 2013
    Covington, La.
    12
    Why would I have to change the output shaft?
    Springfield Mo
    3,309
    Quote Originally Posted by Storyboy View Post
    It is not the right link to line up.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Apr 2013
    Covington, La.
    12
    O ok. So what could I do to get more power out of it?
    Slidell, LA
    4,738
    Sell it and buy a 250r
    Apr 2013
    Covington, La.
    12
    Lmao! You funny. 250r aint turning 27" outlaws. I said power, not speed.
    Michigan UP
    1,005
    2wheel drive trx 300 engine with a big bore kit, cam, carb, and pipe. Now all you need is the skills to do it.
    Apr 2013
    Covington, La.
    12
    I got the skills
    [><]TRIKENSTINE[><]
    Jan 2011
    Brazil, Indiana
    2,087
    In my best Thorny voice from Super Troopers..... DO IT!
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Worcester, MA
    1,117
    Or trx300 engine with trx 350d crank and top end (same top end as 350x), but requires custom made reverse grind cam as the motors run opposite ways. Flywheel side of the 350 crank is better, but can have it turned down or one guy I know of made a flywheel out of the two (inner section was from the 350) but it was slightly off and never ran as strong as it could have.
