Thread: Springs
    tapage is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2012
    Montrose, IA U.S.A.
    166
    Springs
    i went down to my local dealer and they do not make a certain spring for the rear drum, kinda irrtated me its # 10 in the Diagram and could really use this spring like i said no one makes it and the nearest one to me is found in Souix City and i really don't want to go there because the store wont ship or accept my credit card. http://www.midwesthonda.com/fiche_se...84&fveh=133000
    This is the site with the picture in it, not sure what can be done.
    Travis
    Apr 2012
    USA
    4,133
    Mar 2012
    Montrose, IA U.S.A.
    166
    I went to the sight and the one i need has a little hook on the end...
    Apr 2012
    USA
    4,133
    I based it off of the part number from service honda, I wouldn't think they would have the part numbers wrong, but maybe the ebay seller does....
    1981 ATC250R Brake Drum return spring part number: 43413-961-000
    1984 ATC200ES : 43413-969-000
    Yep the part numbers are 8 off, not sure why it came up in my search :-/.
    Here is another result, might want to make sure they have it in stock.
    http://www.cycle-parts.com/Products/...3-969-000.aspx
    and
    http://speedsupplies.com/partslistin...00&category=HN
    Good luck on the search, looks like the TRX200 used the same spring.
    Jan 2011
    Choctaw, OK
    2,755
    Does one of you have an accurate picture of the spring you need? I stripped a bunch of trikes including a few 200ESs and I have a drawer of re-plated springs. I probably have one but I need a pic to match it up to.
    Apr 2012
    USA
    4,133
