Results 1 to 3 of 3
Thread: Hi everyone I'm looking for 86 200x rear axle or info on a conversion
    May 2013
    Rhode Island
    Hi I am looking for a 1986/87 honda 200x rear axle, they seem to be pretty scarce so if that's to much
    Trouble info on a complete conversion would be great, I read that 84 250r axle will work but it was not
    Clear exactly how to go about it, any and all info would be greatly appreciated thanks
    obijuan's Avatar
    obijuan is offline At The Back Of The Pack Arm chair racerFirst time rider
    san antonio texas
    226
    I used a first gen 200x rear axle. More details in my 200x rebuild thread.
    if it aint broke, break it.
    Xfile's Avatar
    Xfile is offline Just Too Addicted Arm chair racerJust too addicted
    Apr 2007
    Shiocton, Wisconsin
    700
    Hi, I converted my 86 200X to the 84 250 R axle. Very simple. 1. remove original axle 2. If your carrier/axle bearings are still good you can leave them in. You will need to grind about 3/16" from the tops of the casting that makes up the carrier adjustment area to clear the sprocket bolts. 3. install a new dust seal on the sprocket side using a 83-84 atc 250 R dust seal, the brake rotor side dust seal will remain the 86-87 200X seal but it wouldn't hurt to replace it with a new one, slide the 83/ 84 R axle in. 4. install the 86 200X brake rotor and hub 5. Use the two 250R axle nuts in place of the anti-fade nut to tighten/install the axle 6. your done, you now have a wider 83-84 R axle on your 86 200X.
    Don't worry...just run watcha brung...
