I just rebuilt my 87 KXT 250. I decided to rebuild because it was smoking and fouling the plug after @ 8 min. of riding.It would start to kinda load up then no power and eventually stall. So I yanked apart the motor, replaced the crank bearings, crank seals, piston, rings and,all other seals.
Now I take it out for the first time and it does the same thing after being rebuilt. The carb is spotless. I did notice my needle on the slide was bent at the top, icould this be the cause,. Should i get a new carb? Do you guys think this is a carb or fuel problem? The fuel I used was fresh. here is a pic of the plug. Any help is greatly appreciated.
SOON MY PRECIOUS!
