Thread: will a quad front tire fit on an atc rim?
    Apr 2013
    washington
    18
    My 350x front tire is bald, and its the stock original one that came on it.
    I need a new one, and was curious if I can get a quad front tire on the rim. Would it work?
    Thanks
    Michigan UP
    1,005
    If it's the same size rim and the other dimensions are the same or close then it should be fine
    Williamstown PA
    5,825
    quad tire is a vage term. if your asking if you can run a new sport quad tire on your 350x rim answer is no. xowner sells 10" conversion rims for quad sport quad tires. I have a 23x7x10 on my 200x. oem sport trike tires were 23 or 23.5x8x11. If you just need a new tire there are a few still sold. The benifit os buying a new front rim is so you can run tires with more selection and thicker ply ratings then the old 2ply.
    the following tires still made for trike rims most people run are:
    cheng shin C832 23.5x8x11 $65.00
    kenda front max k284 a/t 23.5x8x11 $57.00
    If you swap a 10" xwoner front rim on it then you can run any 22x7x10 or 23x7x10 front tires like sport quads some with now days.
    I run a 23" front GBS x-rec on a 10" xowner front rim. see attached pic.
    Apr 2013
    Kansas
    63
    I run a cheng shin front great tire
