Thread: Needle
    JMiller's Avatar
    JMiller is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Needle
    I found my needle in my carb to be bent, it seems to slide up/down the main jet ok. I'm having a prblem with my trike fouling plugs, Could this be the problem?
    Current Rides:
    '87 Tecate 3
    '84 Tecate 3
    May 2003
    Shediac, New Brunswick
    1,126
    that probably has something to do with it
    '84 Honda 200x
    slow restro
    Ashland City, TN
    2,576
    I don't think a bent needle is going to do that. It seems to me that your problem with fouling plugs has to do with either Carburetion or Elecrical problems. Good luck dude.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Mar 2003
    West Monroe, LA
    847
    It's a good possibility. Think about it. If the needle jet is bent that means it's most likely lifting a little higher at each clip setting, the higher the needle raises the more fuel it discharges which means that its getting more fuel at each clip setting and that could cause it to run alittle rich. Not saying thats it for sure but it's worth investigating.
