Well not a ton to go on since you haven't mentioned any attempts to check the carb or when it was last cleaned..I'd say that chore should go on the 'to do' list!
But from what you describe I'd say that you aren't flooding out..but running out of gas!!
If the tank is all rusted inside then the screen in the petcock is likely all plugged and there isn't enough fuel flowing from the tank to keep the float bowl filled. You drive, the bowl empties and you die out from lack of fuel..the slow trickle of gas getting thru partially refills the bowl and you can restart a couple minutes later..
Suggestion to drain the tank, remove the petcock and strainer pipe inside the tank..clean it all then verify the flow by letting the fuel hose dangle in a glass jar as you open the petcock.
Then for good measure tear down and clean your carb..
Do it right, I bet it runs like new!!
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
