Results 1 to 15 of 28
Thread: Polishing NOS plastic. Calling MR. Clean and plastic experts. Help.
    Mar 2011
    Louisiana
    208
    Hey guys,
    I have a peice of nos plastic and there were a couple of very light scratches in it. I used some very mild synthetic polish and lightly rubbed the area. I now have a spot where the plastic is slightly hazy. It is still shiny after buffing it with very light strokes (hand buffing cloth), but will reflect haze rather than having a mirror like finish when looking at it with the reflection of a light such as the lights in my garage, the sun etc. Does anyone know if I could use some kind of rouge / pad to lightly buff out the spot and make it look exactly like factory or am I SOL. Any finishing details would be so great!
    And yes, i know the story. Why am I trying things on NOS plastic. Learned my lesson and luckly the spot is very small and not in plain view. Just would be so cool if I could bring it back to origional.
    Would a felt or muslin buffing wheel with some Acrilustre work?
    Thanks
    Mexico
    9,014
    All it takes is a few good high side crashes and you won't notice that spot at all.
    May 2011
    eden,ny
    3,481
    What brand of plastic? If it's yamaha I wouldn't touch it with a buffing wheel.I have polished kawi and honda plastic with a plastic "rouge" and the proper wheel but the yammi plastic seems to have a lower melting point and didn't work well (for me). Whatever it is, it takes a very light touch with a buffing wheel and chances are it will be harder to do one small spot rather than the whole thing.
    toki is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2011
    wisconsin
    158
    i have a ytm200 that polished up nicely. although i did most of it by hand. sand the oxidized away, wetsand, and buff buff buff. i found that the buffing compound i was using left a residue. i had to take a clean cloth and buff again. and then ANOTHER clean cloth. and then i washed the whole thing down and rubbed some more. a TON of work.
    i also have a headlight housing for my 83 250r that will NOT polish. the oxidation was sooooooo deep on it... i sanded and sanded and sanded. and wet sanded. and sanded some more. i thought i finally broke through to some good plastic but no matter what its still a cloudy pink. anyone ever had this problem? i really dont know what to do with it lol. it has a small crack and i have no problem spending money to replace it. its just pissing me off that it won the fight.
    Rigaman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2012
    Western MA
    403
    What grit is good for wet sanding light scratches out? 400 then 600?
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by Rigaman View Post
    This is a judgement call based on experience. If you can feel them start with around 400 wet. If you can not feel them start with 2500 wet and if it is too fine to remove them then try 2000, then 1500 until you find a great that removes them with moderate effort.
    NEPA
    7,051
    You WON"T be sanding a new piece! Just polishing.Search the threads for the best stuff. Darius was the last polish thread here on his 350X's and they are indiscernible from new machines in the pics. 400-600 would be a starting point for a very heavily scratched/oxidized piece.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by atc007 View Post
    Tamaha3wheeler and atc007
    My post #6 is in response to a question from another member. Please do not use 400-600 on your fender. Unfortunately I have no good answer for your question however. I have downloaded the post I think atc007 is referring to. I will post it later.
    What polish did you use EXACTLY and what cloth?
    All polishes have abrasive in them as far as I know. Anything you try that has ANY abrasive in it will be “experimental” for you and might make it worse. Hard to judge what to suggest without seeing it in person.
    Most polishes MAY have an MSDS sheet available online. This sheet will contain the grit size and type of abrasive material used in it. Find one that is finer and smoother grit than what you had.
    I don’t know what the newest fad is in polishing cloths. I just use old school baby diapers, new no used, lol. I have used microfiber but only on paint.
    You might try imperial hand glaze at least for final finish. I have used it for years, non abrasive, no wax, no silicone. See the link below.
    http://3mcollision.com/3m-imperial-h...aze-05990.html
    You might also call a plastic polisher for info. See link below.
    http://www.eastcoastmfg.com/plastic_...g_services.htm
    May 2003
    Houston, Texas
    2,409
    My last step was just a Maguires foam buffing wheel on a rotary buffer. It did add shine back to dulled out plastic...but be careful. Honestly...I'd leave it alone.
    I would just put some Novus 2 on it. Let it dry. Butff it out with this pad below:
    http://www.ebay.com/itm/NEW-Novus-8-...item43bbe01d59
    BUT If you BURN IT ITS RUINED. VERY DIFFICULT TO DO RIGHT. I'd leave it alone....
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    May 2003
    Houston, Texas
    2,409
    Quote Originally Posted by Yamaha3wheeler View Post
    Hey guys,
    Thanks
    Let's see a pic of it. Let's see the scratches.
    Dirtbikes:
    1988 Yamaha DT
    Oct 2006
    2,502
    Here are the pics I got from the "dude".
    Not sure what tools the "dude" has available, buffer, pads etc.
    What I would do is get out my Dewalt high speed buffer with black foam polishing pad and apply some 3M Perfect-It 3000 Machine Polish 32 oz. - 06064 and follow up with some 3M Perfect-It 3000 Machine Polish Swirl Mark Remover 16 oz. - 39061 followed by some finishing wax (no cleaner wax!!!) from your FLAPS (friendly local auto parts store) I prefer Eagle One NanoWax as it comes with microfiber towel. I would also put a blanket or something between the fender and the tire to alleviate the downward pressure I use to "buff".
    If anyone wants to learn this process I would say prep a car body panel, paint it BLACK, and then wet sand and buff to a mirror shine ....this will teach one how this process is done.
    There are many variables, what kind of towel was used, what kind of product, were you primarily using fingers and not the palm when rubbbing (that sounds so wrong) but if your using the point of your finger you will get scratches versus the blunt surface area of your palm.
    Unfortunately the tip of your front fender is in plain view, next time do it on the back of the fender which is not in plain view
    Mar 2011
    Louisiana
    208
    Thanks for the advice. Oh, and dude = Chris. Sorry about that. Your comments cracked me up about the finger. No, didn't do any fingering. Just palmed it. And I did it very gently! But seriously, you can only see it in the reflection of light. I'm just going to leave it alone since I don't have polishing skills.
    Feb 2003
    New York
    619
    If you used mild abrasion like scotch brite or comet steel wool ect then you can go straight to 2000 grit Maguires sandpaper. Its made in Japan and needs to soak in water 15 minutes before you use it. You can do it by hand. Get the fender off the bike. Wash it good. Get a bucket a sponge that you use for the kitchen sink and a peice of the 2000 grit sand paper.
    Get some simple green or fabuloso. Add some soap into the bucket. Wrap the 2000 grit paper around the wet sponge ( do not squeeze water out of the sponge) You will be using the sponge to hold water while you wet sand and it will prevent burn marks from your finger tips. Do the entire surface of the plastic. Sand wiith medium to light pressure and follow the lines of the fender the long way. Sand for about 30 minutes. Dry off plastic. It will look hazy dull when you dry it off. Dont freak out. Get some Maguires ulimate rubbing compound. Rub that in with a damp sponge in circular motions. Go in all different directions.
    Add some more compound if needed. If it dries up on you mist some water on it to wake up the compound. Do that for 40 minutes by hand. Wash it off with water and a clean damp sponge. Now get some butchers bowling alley wax. Put that on the plastic. Drink 6 beers. By that time you will feel better and wax will be dry. Buff it out by hand or for a better shine use a buffing wheel with light pressure. From there on in the best way to keep your plastics looking fresh is with that foam tire shine stuff. Hope that works out for you. Good luck
    ♠ 58 ♠
    Ride 3
    Oct 2006
    2,502
    Um okay. In my humble opinion using any type of sandpaper is going backwards. That fender does not need any sanding, just polishing at this point...my opinion.
    However I am in violent agreement on "Drink six beers" so long as your of age.
    Quote Originally Posted by sweetip2000 View Post
    Drink 6 beers.
    May 2003
    Houston, Texas
    2,409
    Quote Originally Posted by Mr. Clean View Post
    Agreed as well!!
    Dirtbikes:
    1988 Yamaha DT
