'idk' = I don't know, Barnett
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
Current toys..
1990 Honda TRX300FW
1995 Seadoo GTX
Hello dylanisaacs
Let us know haw it carburetes too if you want ie any flat spots or burbles/stutters?
LOL.
That’s funny I didn’t see Dougspcs OR tri again either in his original post regarding this topic which was first posted on 5-12 at 11:44 am [as seen by his original url below]. I replied to it on 5-13 at 10:17 am. His next new thread he started because I suggested it to him [in his original post] as you can CLEARLY see in my reply pasted below] was in the “NEW MEMBER DISCUSSION” forum and was started on 5-13 at 1:20. Your first reply to that string was on at 1:35 followed by tri again’s post on 5-13 at 1:38.
I hear they have FREE math calculators available online at math.com if you need one to do the simple arithmetic required here to prove that my statement regarding this question is 100% ACCURATE.
Uh Oh, Hello Doug, Doug? I think someone better bring the oxygen!
xxxxx
Oh my goodness no, my nursemaid makes sure I don’t.
xxxxx
DYLANISAACS ORIGINAL POST
http://www.3wheelerworld.com/group.p...893&do=discuss
dylanisaacs - 05-12-2013, 11:44 PM
i am trying to troubleshoot my proble with my 1985 honda big red 250es i drive it for a while then it bogs out randomly and shuts off (like someone flooded it) my friend said it might be the air screw but i think its worse than that, please help me......and if i wait 1-2mins it will fire back up but it might bog while idle and shut off it only recently started doing this any ideas on how to fix this will be much apprciated
Report
# barnett468
barnett468 - 05-13-2013, 10:17 AM
Hello
Please answer ALL the following questions in line order fashion then if you want you can cut and paste them in the NEW MEMBER DISCUSSION forum. You will get many quick replies there otherwise I will try to help you..
How long has it had this problem?
How old is the gas?
How many hours on the spark plug?
Remove plug, what color is the porcelain tip, lit tan dark tan, dry black or moist black and gooey?
Drain float bowl gas into a narrow clear glass via the drain screw bon the very bottom of carb, turn it counter clockwise. What color is the gas? Is there sediment in bottom of glass? Is there a small clear water bubble in bottom of glass?
Sounds like either sediment in tank blocking the fuel filter or a bad CDI unit.
i pulled my plug today and it was white how do i fix it?
Hello dylanissacs
Glad your bike is still running. When we left off, your dad put oil in your tank to stop the rust and added fuel stabilizer. Your bike ran but you didn’t say if there was any carburetion issues after I asked and your plug was dry and black. Now all of a sudden your plug is white.
Based on your bikes history I suggest you do not ride it until you answer the following questions so we can try and see what’s going on. If it is super lean it might get damaged from running too hot. If your plug has only been in for 30 minutes or less it might not have been in long enough to get color on it, but it still seems lean. I have never seen a bike have a plug that had a plug that had less than 20 hours on it and was totally black go to having a new plug that was totally white for no reason at all. If your jets got plugged that much between then and now your bike would not run so you must have done something in between then and it would help me to know what it was first.
Please answer all the following questions so I or another can help you better.
Did you change or do ANYTHING besides your spark plug since the last time you posted?
Did you still have oil in your gas while you were running with the new plug?
What number was the old plug?
What number is the new plug?
Did it burble/stutter upon acceleration with the black plug?
Did it have any flat spots [no burble or stutter upon acceleration with the black plug?
Does it run the same now as it did with the black plug?
Does it idle the same as it did before and does it idle ok?
Does it still require the same amount of choke to start now as iot did when the plug was black?
Do you notice your motor running hotter than it did before?
Does your exhaust pipe glow red after a while?
How long has your new plug been in there?
Do you know what your main and pilot jet sizes are?
Current toys..
1990 Honda TRX300FW
1995 Seadoo GTX
