I bought an 85 250es Big red a few months ago from a guy that had been through a flood and then sat for about 5-6 years. From what I was told and could see it had not been under water just sitting in and floating for about a month till the water receided. The guy told me that they couldnt get any spark and that they had tried to bypass the kill switch and the key switch to eliminate them as the cause for no spark with no luck. So I paid 100 bucks for it and brought it home with the intentions of selling it for parts to a buddy of mine. Well after a few conversations he didnt want it and i was stuck with it. After looking it over a few times i decided to fix it and keep it so i began dianosing it ( swapping CDI's, stators, ohming everything in the process and grounding the neutral safety wire to the cdi in hopes of getting spark) and I finally narrowed it down to the cdi( test one was bad too) and began looking for another one and found that they where pretty pricey considing i still wasnt sure if that was the problem. So after some thinking and reseach I ordered a chinese CDI box for 10.88 online. Once i got the CDI I removed the pins from the connector and using wiring diagrams on here and elsewhere for the CDI I plugged the pins from the CDI into the harness connector. After double checking everthing was hooked up right i kicked it over and it fired on the 2nd kick.this is the CDI box i used because is has the pigtail and it has no rev limiter which may be good or bad. But i hope this helps someone else
