Thread: Tire Size/Gearing Chart
    Apr 2010
    Indian Falls, NY
    1,289
    Is there a specific chart on the board (if there is I apologize, can't find one) that has information on tire size and gear correlation? I think it would really help a lot of people out.
    As in what size tire helps low end and what gear would retain top end throughout the most common sizes.
    Mountain Home, AR 72653
    500
    Smaller tire will lower geared. taller tire opposite. All this to a certain degree.
    1984 Honda 200X
    1999 Kawasaki Bayou
    2000 XR 200
    Apr 2010
    Indian Falls, NY
    1,289
    I know that. I'm looking for a reference chart that will show figures as to what will produce what result with different sizes.
    Example:
    22" rears with a 42 tooth sprocket = "insert MPH here", moderate accleration
    20" rears with 37 tooth sproket = more low end and equal top end
    That kind of thing but for all tire sizes and sprocket combos
    Nov 2009
    Albert Turkey New Mexico
    131
    Maybe this will help, you will need to find out your high gear ratio, then substitute your final drive for their ring & pinion, by dividing your rear sprocket teeth by your countershaft. http://www.csgnetwork.com/rearendgearcalc.html
    I'm not bipolar I'm tripolar!
    May 2008
    Tenn
    548
    I believe that El Camexican did a chart once upon a time. You could ask him where the link is if he did.
    Quote Originally Posted by slashfan7964 View Post
    Example:
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
