Results 1 to 15 of 21
Thread: Is this 350x head fixable? valve seat welding/cutting. pics inside
    Worcester, MA
    1,117
    I am wondering if this 350x head is fixable, and even worth fixing?
    Hate to toss it as it has good journals and exhaust studs/threads. Looks like the seats can be recut, or used with oversized valves? Any idea what it may cost to have done?
    Thanks!
    Attached Thumbnails Attached Thumbnails 2013-05-18_14-24-19_803.jpg   2013-05-18_14-23-11_224.jpg
    Apr 2004
    Brigham, Québec, Canada
    1,528
    I'm no help, but what happened? A valve dropped in the cylinder?
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    6,807
    Its a door stop , not worth fixing ......
    tblumer's Avatar
    tblumer is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    Liverpool NY
    225
    There is a guy that goes by storminnorman over at planetminis.com that could fix that for you, he's brought back heads form worse damage.
    84 ATC 70 w/88 (for the kids)
    85 Yamaha YTM200 (Protek suspension / Tecate forks)
    74 Joker frame ATC 90 w/ 110 cdi
    71 Honda Z50AK1 Mini Trail w/117cc stroker
    CRF50 stunter w/117cc stroker
    08 Yamaha WR250X
    My feedback:
    http://www.3wheelerworld.com/showthr...89#post1080789
    Lewiston, N.Y.
    1,477
    I second shortline
    Dec 2010
    Back in VA baby!!
    711
    It's always worth fixing...especially since they don't make these parts anymore.
    NEPA
    7,051
    Send it my way. I'll guarantee it for another 20..Ok,not 20,but that is very fixable. It needs the seats recut like you said. Mickey could comment on oversize valves. I would assume that would eliminate ANY doubt. I have saved a lot of 250X's like that one. It takes a lot of tlc with a very steady hand. And the combustion chamber will never be pirty again. But ,the valves will seal fine. I tossed them away too many times!! And I had a customer BEG me to do a 250X 12 or so years ago. It still runs like new. And kicks like a mule Have done a few since. And for my doubters lol... I did them with a dremel and rough/finish lapping compound. I don't own a seat cutter. But you will want a seat cutter ,and you will never look back.
    1,641
    What shape are the guides in?If the engine smoked before they may have been the culprit.The 350x is known for worn guides.not a cheap fix if done in a shop.
    Worcester, MA
    1,117
    It wasn't my engine, I got it awhile back in a parts lot, dropped a valve and piston took it.
    I can press out the guides and maybe clean up some of the chamber, but I'm unable to do any of the seating.
    Pacific NW
    4,255
    we used to reweld aluminum (car) heads all the time.
    Machine down to accept new seats and off they go.
    I forget the cost.
    I can't see to well so not real sure what it actually needs.
    Jan 2013
    minnesota
    5,911
    Hello
    Can't see it well, just take it to shop and get estimate.
    To do it properly you are looking at possibly
    4 valves $80.00? for Shindy’s
    2 seats minimum $25.00?
    Likely 2 guides, probably 4. $40.00? for 4 min
    Misc labor $100.00? min
    Smooth head $25.00?
    [this will lower compression slightly but not by much]
    No guarantee on “good” or “rebuilt” heads on Ebay.
    You might need to redo the top end [new bore, piston and rings]while you’re in there.
    NEPA
    7,051
    I was thinking his piston is probably still good?? lol.. It has 75 pock/breaks in it from 2 valve heads in it ! Yes,he will need a complete top end,bore. And probably a timing chain. Do it once do it right.
    Scootertrash's Avatar
    In the sticks
    4,638
    I would say try to fix it since, as you say, these parts are no longer made. If it were me, I'd do what I could to clean up the combustion chamber portion and leave the valve welding/grinding to a pro since I don't have the tools to rework the valves. It possible that the valve seat(s) could just be replaced.
    If you decide to scrap it, PM me, get my address and send it to me. I'll see what I my machinist can do with it.
    Apr 2006
    London Ontario, Canada
    1,197
    Quote Originally Posted by TheRealFatShady View Post
    Thanks!
    I'm agreeing with the fixable answer, as stated earlier, you can't buy them new off the shelf anymore. If the cam journals are good and there is no hair line cracks in the head, hang on to it until you need it or sell it to me, lol
    R.I.P. Sandpuppie, you are greatly missed!
    May you rest in peace Jeswinehart, deeply missed, never forgotten....
    Feedback thread http://www.3wheelerworld.com/showthr...ight=tapper190
    Nov 2009
    Albert Turkey New Mexico
    131
    Easily fixable, I do headwork from mild to wild all week long. I've fixed heads worse than that one, could even restore it back to stock chamber volume or smaller for more compression, stock or oversize valves. Whatever you want.
    I'm not bipolar I'm tripolar!
