Just bought some used rear tires & the diameter of one tire is about one inch bigger then the other tire.
Befor i measured the tire i test road them it was pulling to the left swaped the tire around an would pull to the right
So the question is i have about 17 psi in the smaller diameter tire & 10 psi in the larger diameter tire to make the differences. But there still not exactly the same measurement still a few mm off of being the same size what else can i do to fix this
