Results 1 to 6 of 6
Thread: 84 200x swingarm bearing parts problem
    Manitoba
    536
    I am replacing the swingarm bearings on my 84 200x. The previous owner has given me the seals, thrust bushings and needle roller bearings to do the job. Finally got around to pulling the old swingarm off and I discover that it is completely different than expected or as shown in the manual. Instead of having roller bearings, it has one piece bushings that act as both the thrust bushings and pivot bearing (non roller).
    Problem is, while the old worn bushings fit the bearing spacer (tube), the new roller bearings have far too large an inside diameter for the bearing spacer tube that they should fit over.
    What kind of mismatch of old parts did I take out with the non-roller pivot bushing and spacer? What do I need to make this fit? It seems to me the problem is with the bearing spacer having an OD that is too small for the roller bearings that should go on an 84.
    Edit: What's the quality of the kits on ebay for around $40 that include the spacer with the bearings?
    84 200x
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    Stock swingarm? Here is a good shop-local option:
    http://shop.3wheelerworld.com/produc...?productid=102
    Jun 2009
    Leander TX
    2,217
    The eBay kits are fine. I used them on my 200X.
    Dave8338's Avatar
    Dave8338 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2013
    Central MN
    378
    I installed the All Balls bearings and spacers (250R swinger) in my project bike and they work perfect. The spacers are the same outside diameter as the 200x and everything went together nice and smooth. Bought them off of Ebay, too.
    The Goal... All I Need Is The Time...
    Manitoba
    536
    Anyone run across a 200x with metal bushings instead of roller bearings? Was that OEM in some early years? I could see a bronze bushing holding up really well and not rusting from water crossings.
    84 200x
    May 2008
    Northwestern Ontario, Canada
    552
    My 86 250r swingarm was so bad I had to take a sledge to get the bolt out, needless to say it wasn't fun. I looked at the bushing idea but went for the bearing option. The e-bay kits have always been good for me. I take the bolt out every year or two and grease it up, no issues so far. I installed a grease nipple on the main bearing carrier as well. Not sure if I could put one on the front needle bearing area as well, it's kind of tight up there...
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
