Another potential problem is that each time that you blend racing gasoline and street gasoline, you do not necessarily get the same end results. This is because street gasoline is “seasonally varied” six or seven times per year based on the temperatures that are anticipated in your particular area. Racing Gasoline remains the same throughout the year, but with the variable of the street gasoline, one can get some less than ideal mixtures that can contribute to vapor lock and/or make consistent tuning difficult.
A good racing gasoline is designed to burn efficiently between 5,000 and 9,000 RPM. A good street gasoline is designed to burn efficiently from idle to 3,000 RPM which is the highest speed most engines see during the EPA test for exhaust emissions. Mixing the street gasoline with the racing gasoline compromises the good high-speed burn characteristics of the racing gasoline thereby reducing the potential engine output. This also reduces the octane quality of the blend.
