Finally got myself something with some power to it, and with rear suspension. I've always run 200 chain drives before this.
I paid $300, and traded my 200m, average price for these bikes around here. I got it not running, the starter gears were stripped, and the 1-way clutch bearing was completely shot. It was being driven until the starter gears went.
It came with the new bearing, but even after putting it in, the kickstarter still barely works, but at least now I can get the bike started. It grabs a lot better to when the motor is warm. I think the part of the clutch that runs on the inside of the bearing is worn. Runs goods now that I got the carb cleaned and adjusted. There's some top end noise tho, and it gets worse and turns to a tap when I get hard on the gas. Valve gap is good, and the timing chain isn't loose.
I'm not a big fan of the rear tires either, they half-worn 26x9.50x10 vampires. To narrow and tall for a trike I think. Is there any common sizes I can find used that would be a better fit for the 10" rims? Maybe I'll just find a set of stock rims and put on a set of 22x11x8's.
Overall I don't think I did to bad. What do you all think?
and I can't forget the pics:
PM me if interested.
