So i was riding my 84 250r yesterday, and about 3 hrs into the ride, my carb got stuck in what sounded like wide open. We pulled the top cap and throttle out in the desert, and saw nothing out of the normal, so we towed it all the way back to the trucks. Today i tore the carb apart to find that the little nylon tang inside the carb had broken off, and was allowing the throttle barrel to rotate. Because it was able to rotate it was catching on the idle set screw. After some research, i found that the little nylon tang cant be replaced, and that basically i would have to buy a new carb. This is when i got creative. I found the smallest diameter screw in my garage, cut it to length, then ground the tip down with a dremel tool to basically make a shoulder screw similar to the idle set screw. After that, i drilled out the remaining nylon, threaded it in, and put a big drop of red locktite on it. After i put it all back together, it started right up and runs great now.
I was just wondering if anyone else has ever had the same issue.
