Results 1 to 8 of 8
Thread: Voltage regulator - need some help
    Worden18's Avatar
    Worden18 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2013
    Minnesota, USA
    298
    The voltage regulator on my 84 YTM 200EL is bad; my neighbor owned the trike for 25 years (since '88) and never had the lights working. I changed the head and tail-light bulbs first, the new headlight blew out at full throttle. I then tested the regulator as per the Clymer manual (page 184) and sure enough there is no continuity thru the regulator, I guess allowing too much voltage to surge thru the system and blow out the headlight.
    Here's what I don't understand. The manual says put the positive lead on the red wire, and the negative lead on the white wire...there should be continuity (I had set my multimeter to beep on ohms). It then says to reverse the leads, and then there should be NO continuity. Well what difference does it make if the leads are switched around when you're just testing for continuity? I'm no expert with the multimeter of course but the test doesn't make sense.
    I've bought (and returned) 2 used regulators from ebay because they don't have continuity at all (parts were sold as working, but obviously they were not tested). Didn't matter which lead I had on the red/white wire, there was no continuity. I'm kinda getting frustrated with this thing, I need the lights to work for night riding. So far I haven't seen a new manufactured regulator for this trike. Any suggestions on this test? Is the regulator on these trikes one of those "yep they went bad/those are junk" parts?
    My Trikes:
    1983 Honda 185s
    1986 Honda 250es Big Red
    1985 Yamaha 225 DX
    1984 Yamaha 200EL "Yamahauler"
    Pacific NW
    4,255
    Wish I knew.
    Terribly frustrating when we do exactly as told and are Still wrong.
    Sounds like someone's girlfriend wrote that fix it book.
    Regulators generally aren't super specific. I bet there are aftermkt units that could work.
    I'll go look on dratv and see if I can find anything.
    Sarnia, Ontario, Canada
    3,415
    Agree..ebay is full of them. May not be the same great quality but if it can be made to fit the application then it becomes yet another way to repair these aging machines since parts are getting more scarce..
    I read a thread the other day of another member using an Ebay CDI on his 250ES..
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Pacific NW
    4,255
    yupp, at least 10 on dratv.com,
    6 and 12v and universal, and for hi output etc
    If nothing else, it's good info to know or extrapolate from.
    Howdy's Avatar
    Celina, Ohio
    10,079
    I use a moose 12v regulator when I have this problem and it's solved every time.
    This is why I keep these in stock.
    Howdy
    blackstone/ma
    1,491
    THe manual sounds like it's full of hore poo. Manuals are wrong more often than you think. Liky howdy said new and universal is the way to go
    Worden18's Avatar
    Feb 2013
    Minnesota, USA
    298
    Thanks for the responses gentlemen. I'll see if I can get a universal one hooked up and then let everyone know how it turns out
    My Trikes:
    1983 Honda 185s
    1985 Yamaha 225 DX
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Quote Originally Posted by Howdy View Post
    Howdy
    How do you plug these regulators? Inline on the + side or you groung one of the wire?
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
