Originally Posted by
RIDE-RED 250r
Well, you were very close when you had the bowl off the carb before.
Simply remove the bowl. Now flip the carb upside down and you will notice a sort of tower protruding upward as the carb sits upside down. At the very top of the tower, you will see a sort of brass fitting. The main jet is screwed into this tower and is removed with a common screwdriver. Remove the jet and look through it. If there is anything whatsoever in the fuel passgae through the jet it needs to be cleaned with compressed air.
The pilot jet will be found in a secondary casting on the side of the main jet tower. It is usually recessed and not as readily visible as the main. On the side of the main jet tower casting, look for a small hole. Inside that hole you will see another brass fitting with a common screwdriver slitted head. This is the pilot jet. Using the appropriately sized screwdriver, remove the pilot jet and inspect it as you did the main jet. This is key, just like the main jet, the pilot jet has a fuel passage running it's full length. But it is MUCH smaller than the main jet. Hold it up to a light source and check to see if it is partially or fully obstructed. If you cannot see clearly through the tiny hole against a light source it will need to be addressed with compressed air. In some cases a jet can be clogged with stubborn enough deposits typical cleaning methods won't cure it. Sometimes you just need to replace the jet with a new one. If you attempt to use a small drill or other solid probing object in a jet (particularly a pilot jet as the hole is so tiny) you can inadvertently enlarge or damage the fuel passage. Any change in size or shape of that fuel passage will alter your fuel mixture.
While you have both jets out, inspect and blow compressed air into the fuel circuits you removed the jets from to ensure no blockages in the carb body fuel passages. On the main jet, you can actually remove the main jet tube and make sure the emulsion holes are clean and clear. This is removed usually with a 6mm socket or small adjustable wrench.
I will be going out to re-jet my son's '85 ATC110 here in a little bit. I will take some pics and post them up for you to help you identify what I'm talking about. It sounds like a daunting task, but I assure you, it's not nearly as difficult as it may sound.....
