Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: 125m electrical issues...is this common?
    May 2007
    Coshocton, Ohio
    1,815
    Forgot to mention, glad you got it fixed.
    I'm glad too. Thanks!!!
    I never did check the output directly from the stator.
    Appalachian American Racing
    the home of
    May 2007
    Coshocton, Ohio
    1,815
    Quote Originally Posted by dougspcs View Post
    Did this also fix the key off issue?
    Everything works properly now. I think the key off issue was corrosion on one of the connectors. I went through and cleaned them all and put dielectric grease on them all. I figured that I better do that to eliminate a faulty connection as the cause of my charging issue. I'm glad I finally got the gremlins worked out of it. Now I can ride it!!!
    the home of
    MN
    3,263
    12.74 at idle isn't that bad. A fully charged battery is around 12.6v roughly, so if its at 12.7 at idle the battery is fully charged or nearly full, as the engine rpm increases the voltage increases as well, but that doesn't mean the battery needs to be at that voltage, the voltage just rises with the regulator cutting off around 13.8v.
    Sounds like you got it working!
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
