Results 1 to 9 of 9
Thread: Fun things found disassembling an engine.
    Worcester, MA
    1,117
    I got this dirt cheap for parts. Think the guy was trying to strip it down and part it out, but didn't finish.
    Things to note:
    The flywheel was BEAT. You could see he had whacked it a bunch with a . If you must beat on something on an engine with a , at least use a rubber mallet or lead. And use the correct puller, even some axles have the same threads I believe..... I pulled a whole side case, flywheel, starter gear, etc in maybe 5 minutes or less just last night. It's worth it to buy the right tools. (Electric impact and flywheel pusher bolt.)
    Don't use hard metals to lock gears. Use a penny. Or use/make a correct tool. Do NOT use a cheap set of pliers.
    This is what I found when I split the case, I could see some stuff in the bottom, figured it was the cases' missing portions, also from being hit with a .
    Didn't get run like this or else there'd be noticeable internal damage, but just goes to show that you can really mess up an engine and risk breaking things if you don't do things right and use the right tool. It's amazing that this crank end wasn't stripped with the LH nut.
    This was supposed to be just a short rant, but I tend to get carried away. You guys ever found anything odd in engines?
    6,819
    Nice . Had a 200x come threw the shop recently were the owner TRIED to rebuild the tranny himself ... He installed two gears backwards and had a few washers in the wrong spots , welp guess what it started and locked up . few hundred dollars later it was good as new !!!!!
    Williamstown PA
    5,825
    ouch. my 200x had a carpenter ant in the oil pump and rocks in the bottom end....not sure how that got there but it was rebuild by my friend who is a deisel machanic....yeah.
    one xr200 i owned had a screw in the top of the carb.
    STL
    3,560
    thats a mess!
    Jan 2011
    VA Baby
    225
    fat shady... what is all that?? it looks like a piece to needle nose pliers... and parts of a glass "tobacco" pipe
    which would actually explain why the pliers were there....
    I never found anything too interesting inside a motor... but I once bought a 85 200x for 50 bucks because the guy tried to rebuild it & could never get it running... only to find out he never installed the key on the cam for the cdi...
    Safety 3rd
    Mexico
    9,019
    Buddy's 500+hp 454 fresh out of the "Speed Shop", a 7/16" wrench in the intake port of the head. Found it because it was banging around while running, so he pulled the manifold and there it was. Called the mechanic and told him and the guys just says "oh, I've been looking for that wrench, when can you drop by and bring it back?"
    stoshu is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2011
    winnipeg
    249
    was it Softys?
    Lancaster, PA
    1,738
    Walnut stuck in the rotary on my Tiger 200, thought it was siezed, but it was just jammed,lol
    http://www.3wheelerworld.com/showthr...ger+200+walnut
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Jan 2011
    VA Baby
    225
    ohhh. my dads kawi prairie start making a BUNCH of rattling when fired up one random winter day (just rode it the day before) .... it was brand new back then.. so he took it back to the dealer... apparently a mouse thought the air intake boot was nice & warm place to hide some dog food
    Safety 3rd
