Results 1 to 7 of 7
Thread: taking off front tire off
    Arkansas
    54
    Ok I unbolted the bolt couldn't get the axle off I messed up the castles beating the thing I heated it up with a torch on the spacer on the other side of axel and it went in flush with shock and still wont come out used pb blaster and were is a good place to get new axle can't find on ebay and its a 83 200e honda and what are some good tires and is it better to replace the rims I was told I should go to a one piece instead of two piece rim
    honda 83 200e
    Sarnia, Ontario, Canada
    3,415
    Quote Originally Posted by Bigtyny View Post
    Ok I unbolted the bolt couldn't get the axle off I messed up the castles beating the thing I heated it up with a torch on the spacer on the other side of axel.
    it went in flush with shock and still wont come out. I used pb blaster.
    where is a good place to get new axle? can't find on ebay. its a 83 200e honda.
    also what are some good tires and is it better to replace the rims?
    So hard to read as one long run on sentence..some punctuation makes is easier to read and will get you more response!!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    3,415
    In response to your questions now..there is not easy way to get a siezed axle out sometimes. I have found that if you can get the axle unthreaded from the left shock you can undo the cap on the right and remove the wheel. then unbolt the rim and put the hub in a vice to get a better handle on it..then using a punch and go at it.
    If you are tire hunting, you might as well go rim hunting..the split rims are a pain to RE&RE tires from and usually the corrosion around the rim halfs make it tough to get a good seal once broken.
    Check the classifieds section..there are bound to be members with the parts you need for the asking..
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    May 2009
    S.E. Michigan
    1,251
    I tried removing the front axle bolt on my 84 200ES (same exact front end as your 83 200E) but mine wouldn't budge. What happens is that the steel bolt siezes (in a major way) to the aluminum spacer and the fork sliders. Mine came out... in three pieces after I used the sawzall to cut the bolt. I was able to drive the remaining pieces out of the fork legs, but not the spacer. The bolt was pretty much welded to the aluminum spacer.
    So, I can't offer up any real suggestions for getting your bolt out (intact anyway) but for sure, if you get replacement parts, invest in some anti sieze and coat the heck out of the bolt. I make that part of my annual maintenance now. I try to pull out bolts like that and reapply anti sieze when getting the machine ready to ride in the spring.
    Good luck with yours!
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    STL
    3,560
    sawzall and a press to get the last pieces out may be your best option. I have had to do it with swinger bolts before
    Buck Snort's Avatar
    Buck Snort is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2011
    British Columbia
    398
    I just stripped a 200e down. I bought it off a farmer, it had been used for chores for years. Covered in cow crap. The funny thing about this is, I fought with everything on this rusty beast, excpt the front axle. Had the front tire and hub in the parts pile in maybe 5 minutes.
    Arkansas
    54
    How do you take the right cap off? What size rims can I use?
    honda 83 200e
