Results 1 to 15 of 20
Thread: rat bike 500 for trikefest
    May 2011
    eden,ny
    3,481
    After seeing a few other 500 builds going I figured I would jump on the bandwagon. The trike started out as a pile of parts that once was fabiodriven's 500 project. I had an 86 kx 250 engine that was destined for the frame.However in the time of the parts making there way from Mass. to western NY a 1990 kx 500 became available. With a little wheeling and dealing the kx basically cost me gas money to pick it up 4 Hrs away. This is definitely a 10ft rat bike but it's still a 1/2 liter bike. This bike has mismatched,rusty and maybe some missing hardware. The pipe was smashed up pretty bad and was probably better suited for the scrap pile than to be put on a bike. The swingarm is a plus 2 laegers that had plates welded to it and was not a very pretty sight.That probably should have ended up on the scrap pile aswell. The fender brace was from mik6's bike that Dawn ball wrecked at tf. That was broke in half and twisted. The grab bar is for a 250r modified slightly to fit the t3. This bike was put together with spare and junk parts and definitely qualifies as rat ride,lol. But damn it's fun to ride!! Heres a few pics to drool (or puke) over.Click image for larger version.
Name:	old pics 829.jpg
ID:	170668Click image for larger version.
ID:	170676Click image for larger version.
ID:	170675Click image for larger version.
ID:	170674Click image for larger version.
ID:	170673Click image for larger version.
ID:	170672Click image for larger version.
ID:	170671Click image for larger version.
Name:	old pics 833.jpg
ID:	170670Click image for larger version.
Name:	old pics 831.jpg
ID:	170669Click image for larger version.
ID:	170677Click image for larger version.
ID:	170678Click image for larger version.
ID:	170679 I did a number on my lawn, I guess I shouldn't ride it in the yard after a hard rain.
    Mexico
    9,020
    So is it going to TF??? I think a 'Battle of the Big Bores' post with a poll needs to be put up so predictions can be made on the drag race outcomes. Trash talk welcome!
    ShaftDrive225dx is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2012
    washinton st.
    206
    I want a two stroke damnit! lol very nice project hope all goes well good luck?
    Slidell, LA
    4,738
    That actually looks pretty decent Ben. Nice work!
    STL
    3,560
    rat bike?! looks pretty nice to me lol the pictures make it look well put together too, did you do the decomp head yourself? Also hows the shoulder doing? Fabio going to race this one for ya
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by JasonB View Post
    larry weichman from kx riders forum did the head He did a sweet job on it and was less than 2 weeks total turnaround. He does them for the cr too. I believe Fabio is piloting his and Dans bike but he certainly is welcome to mine any time(it's still his bike right now technically)My shoulder is a lot better than the last time you seen it but if I go down at all I will be healing from the beginning again. That's why you won't see me on the mx track this year. This bike may make on the track though,I was gonna let MTS ride it or my 250. I think the bike he was going to race will be staying in NY because of room constraints.
    Blossvale NY
    4,563
    That doesn't look so terrible Ben! Looks alot better than MY 500!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    tblumer's Avatar
    tblumer is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    Liverpool NY
    225
    I see my old 70!
    84 ATC 70 w/88 (for the kids)
    85 Yamaha YTM200 (Protek suspension / Tecate forks)
    74 Joker frame ATC 90 w/ 110 cdi
    71 Honda Z50AK1 Mini Trail w/117cc stroker
    CRF50 stunter w/117cc stroker
    08 Yamaha WR250X
    My feedback:
    http://www.3wheelerworld.com/showthr...89#post1080789
    May 2011
    eden,ny
    3,481
    I forgot to mention the frame being twisted LOL. It's good enough for now but that will be replaced in the future.
    Aug 2004
    Ab Canada
    4,368
    Ill ride it, cant be any worse than the honda"s I rode in the last couple years!!
    1985 Tri-Z-
    Sep 2005
    MICHIGAN
    2,027
    Cool project, I'm still looking for a quick solution for front motor mounts (and even upper ones maybe). What did you use?
    I dont have a welder either. Did you just bend/dent the cross member tube for the spark plug?
    86 T3
    84 T3
    86 KX250
    Nice job Ben! I'm sorry about the frame, I had no idea it was twisted. I picked that bike up half built as a 500 and the kid was a total hack and a ripoff. It was before I was on the forums.
    Yes, the hack I got the bike from dimpled the frame with a for the spark plug.
    May 2011
    eden,ny
    3,481
    Quote Originally Posted by nd4speed View Post
    I used 1/4" aluminum plate. I cut the rough shape out that I needed with a circular saw and used an angle grinder (with and aluminum wheel) to radius and clean them up. I clamped them together in a vise when I did that so that they would be the same. After I had the shape I needed I clamped 1 of them in position on the frame and used a transfer punch to mark the holes. Then put both mounts back in the vise and drilled them both at the same time. Its the same for the top mount except I made some bushings to space the mounts off the frame. You could use washers for that but I have a lathe for stuff like that. The only welding I did was welded a second mount on the frame for the silencer. I will have to weld a tab on the left radiator for the shroud mount. I used the kx 500 left radiator to simplify plumbing. The tecate radiator wont work without modifying it or the cylinder head. I'm not too worried about the frame Fabio, I will find a nice one in the future,Then hack this one up for some other crazy project I'm sure.
    Sep 2005
    MICHIGAN
    2,027
    Thanks for the info, I was just going to cut some steel plate stock. I always ask cause someone might just say it's easy like "slot the holes on some KX5 mounts". But it seems everyone just fabs some. Ok no big deal. WAs hoping there was simple way to dimple frame too.
    86 T3
    84 T3
    86 KX250
    STL
    3,560
    Quote Originally Posted by just ben View Post
    very cool. And ya stick that damn Canadian on it, hes so light the bike will just fly
