Thread: Gas tank issues
    Apr 2008
    somerset ma
    1,822
    Gas tank issues
    My Brother has a 1980 KAWASAKI KZ1000 A4 model...The previous owner had used some of that POR sealant stuff in it. Over the years, (mind you, the bike was in storage for close to 14 years with the tank being empty) that stuff is breaking off and causing big problems.. He cant get at it to try to break it up and take it out of the filler hole.. He took it to a couple of places and they told him that they couldn't do anything about it.. Does anyone here have any thoughts or suggestions, on how to take this crap out of the tank? His last resort is going to be cutting the bottom of the tank open, then peeling back the metal, then re-welding it back up... Thanks for the info if any... Tank
    Grand Rapids, MI
    522
    And old school trick was to put some bolts and nuts in the tank, and shake it all around for a while.. the bolts and nuts should knock free whatever is in there. I've used the same technique in cleaning some rust out of a tank and have been successful as well.
    Gunter glieben glauchen globen
    The Good:
    1985 1/2 Tri-Z - Daily Rider - Pretty much stock ( wink )
    1985 1/2 Tri-Z - Custom Black & Gold, Top mount plastic tank, custom 3D printed airbox, Banshee shock
    1985 Tri-Z - Rider restore in process
    The Bad:
    1988 TRX250R with 86 ATC 250R Motor and Swinger - Screamer!
    The Ugly:
    1993-ish Banshee / 2003 Motor by VSR in Belding, MI - Duner Fun!!
    2000-ish Banshee / Motor by RDZ Racing in Fowlerville, MI - Another Duner!
    MN
    3,263
    Pour in some MEK and some nuts, agitate it now and then, pour out... I have eaten the coatings out of tanks with MEK, worth a shot.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Sep 2009
    Suring Wisconsin
    967
    Quote Originally Posted by kb0nly View Post
    This will work but takes some time. You can sand blast the inside of the tank. Cover around the bung with good masking tape then duct tape to avoid hurting the paint. I used a hand held one with lots of psi. You will have to use the same product it had unless you get every bit of liner out, which is very hard to do. The sand blasting is a mess but it works. If you have a shop vac set it up near the filler bung to suck the dust. Once all blasted rinse with mec.
    Rebuilding and riding trikes everyday and lovin every minute.
    http://www.3wheelerworld.com/showthr...light=pipeline
    Apr 2008
    somerset ma
    1,822
    I forgot to mention, the part that is giving him a hard time is, there is a huge chunk of the stuff that got knocked loose and it is too large to get out of the filler neck. He tried breaking it up with pliers and other tools with no luck. Thanks for the suggestions guys
    MN
    3,263
    If you got big chunks like that then let it soak... Fill it with some MEK, be mindful of spilling it on anything painted including around the fill hole of the tank. Fill it up let it soak, yes it will take time, but it will dissolve that coating, and the large chunks will get soft enough that you can pull them out. Been there done that, it sucked!
    Apr 2008
    somerset ma
    1,822
    I will pass on the suggestion, thanks TANK!!
