My 84 big red is blowin smoke out the exhaust. I just assumed that if I changed the rings that the problem would be solved but according to someone I was talking to there's a lot more to it than that. He told me that I would probably have to do the valves, get the head honed and bore the cylinder and get a new piston along with the rings. As well probably have to get a new timing chain. Is this actually the case or am I correct in assuming that doing just the rings will solve my problem of burning oil? There is a tick coming from the motor as well but was told on here that the 200 motors pretty much came from the factory with a tick.
